| diyAudio Sponsor | ||
Hi all.
I just finish TriodeDick's Bill. Sounds fantastic I'm thinking if there is a 6sn7 subminature.. it dosen't need to be a twin triode..i can use 2 tube's (one for each channel Thanks //Daniel |
#2 |
6CG7 is the electric equivalent to the 6SN7-GTB and sits on a noval socket...
what to you consider subminiature...? |
#3 |
Be sure to send me your "ugly" 6SN7s
#4 |
6021 isn't that far off -- mu is a bit higher, but rp is pretty similar and it can probably be used in many SN7 circuits with just a little adjustment.
http://www.ecpaudio.com |
#5 |
diyAudio Senior Member
IIRC that's the only submin type that comes close. Cheers,
Frank |
#6 |
These are what I used to replace my ugly 6SN7s, but you'll probably think these are even uglier!
7193 @ The National Valve Museum |
#7 | |
IMHO The 6SN7 despite its size is pretty hard to beat, and I don't think the 6021 is in quite the same league. Besides we like big tubes, right?!
www.kta-hifi.net |
#8 | |
Seriously, the triode in the 6SN7 and its close relations is REVERED for very good reason. With NOS 6SN7 prices in the stratosphere, it's nice that 2 decent variants, EH and reissue TungSol, are in production at New Sensor's Saratov, Russia, plant.
Eli D. |
#9 |
Speaking of nice dual triodes, has anyone tried/heard the 6C8G. On paper it looks very good, but in practice I don't know how it will sound with one of the grids being the top cap. I'm going to try one as a driver in a little SE. It may need a follower as it doesn't look too strong in the drive department. I have a ton of B+ available (over 400v) so a CCS plate load sounds like an idea.
Can't beat the retro looks of the bottle though Best part is that they are still pretty cheap. Gary |
#10 | |
http://http://tubedata.milbert.com/s...137/5/5977.pdf
Au rutti wop-bop-a-loom-bop-a-boom-bam-boom - Richard Penniman |
| 6922 vs 6SN7 | henryp | Tubes / Valves | 112 | 24th April 2011 11:27 AM |
| 6SN7/6SN7 Aikido + CS4398 DAC = HEAVEN | john65b | Tubes / Valves | 19 | 10th January 2010 03:13 PM |
| Help me.......What is the 6SN7 ??????? | cd149dc | Tubes / Valves | 10 | 17th June 2007 04:09 PM |
| Is it the 6SN7 or me? | arnoldc | Tubes / Valves | 4 | 12th October 2006 11:31 PM |
| Page generated in 0.10423 seconds (79.85% PHP - 20.15% MySQL) with 10 queries |
