| diyAudio Sponsor | ||
Hello,
I built an aikido phono amp about a year ago. I've made a few changes and replaced my input tubes with some that sound a bit better but have lower gain. I still get enough volume, but before I'd turn it up about 1/2 way, and the music was much louder than any buzz/hum. Now, I need to turn it up almost all the way (for relatively loud listening) and the background noise is much more noticeable. This was my first p2p project, and I just can't get this last bit of noise out of it. Then on to the needle.. It's a high output moving coil.. so relatively low output. (1.6mv) SO, my question.. Would adding input tx's be a good idea to boost the clean signal from the TT, so I wouldn't need to turn up the volume and amplify the background noise so much? thanks!! |
#2 |
1.6mV is a bit high for use with most moving coil SUTs (step up transformer) and the commonly employed alternative vintage mic SUTs. your HOMC cartridge may well be happiest loaded into 47K (the several I had all performed best into 47K) which is what they are usually designed for.. A better idea would probably be to find some good sounding, low noise, and higher mu triodes for the input stage of your Aikido.
I use SUTs with my Zu/Denon DL-103 (370uV out) and tried quite a few pairs before I found something I actually liked.
www.kta-hifi.net |
#3 |
I've got the dl-110. I played around w/ the input load when I built it. I ended up going way lower than the recommended 47k. It's been a year, but if I remember correctly, it was was a bit slanted towards the high end. I believe I settled on 4.7k for the input which sounded more balanced to my system/ears.
Maybe I'll play with that some more now that's it's had a year to break in. I just read something saying the lower input imp., the lower the output from the cartridge. (specifically said once you put it on a MC input at about 600ohm's, the output of the cartridge drops to about .8mv) |
#4 |
Ok, put the resistor back to 47k, and I do believe it sounds better this way.. It's a bit louder, so covers up more of the background noise. Also, now that things have broken in, it does sound better w/ the recommended 47k. The tone is still even, and everything is a bit tighter/punchier. I know that's about as non technical as I can get, but I think u know what I mean.
Since I'm the only one who even noticed the noise, this will probably hold me over till the next time I get hyper critical.. |
#5 | |
You will have to experiment with the load presented to the trafo's secondary, in order to maximize performance. Send Steve Eddy a PM or EMail if this method is of interest, as he is expert in the use of mic trafos as means of obtaining voltage gain.
Eli D. |
#6 | |
Sheldon Last edited by Sheldon; 4th August 2010 at 01:19 AM. |
#7 |
it's only slightly worse than that (ear next to speaker). I don't hear it in my listening position, but in a few spots as I walk around the room.
The reason I brought up the topic is that when I had higher gain input tubes, noise was not an issue. You'd have to turn up the volume far louder than any listening level to hear the hum. With the lower gain inputs, I hear the hum more.. still, just barely. But, I agree with you. I'd rather not hear it at all with the input tubes I want to use. |
#8 |
Well, I want to close this thread out by mentioning....
I basically moved some things and rewired all of my equipment (interconnects.. not under the hood) and the noise is gone!! I have no idea where a signal was running next to mains or whatever was going on, because I did look for that sort of thing while trying to chase down the buzz. Anyway.. happy days.. |
| Why balance input for phono amp? | Sunsun22 | Analogue Source | 37 | 1st December 2009 09:54 AM |
| Adding Pass through input on my pre-amp | RollE2k | Parts | 3 | 27th June 2008 03:47 PM |
| 2 cartridges, one phono input question | dario54 | Analogue Source | 4 | 1st December 2007 06:10 PM |
| Adding extra attenuation to S&B TX-102 | mlvp | Everything Else | 10 | 13th July 2007 12:32 PM |
| Adding a 2nd input to small practice amp | nfway | Chip Amps | 4 | 20th October 2004 06:53 PM |
| Page generated in 0.10895 seconds (80.98% PHP - 19.02% MySQL) with 10 queries |
