| diyAudio Sponsor | ||
#2 |
Can't see anything from your link.. Wish people would not post links to things that require login credentials to view them...
www.kta-hifi.net |
#3 |
#4 | |
Despite the mention of the Marantz 7 this phono stage appears to be quite different using passive EQ, the placement of the passive EQ is interesting in that it is between the second gain stage and the cathode follower, this might provide some SNR advantage particularly with low output MM and the high output end of LOMC, but might in some cases with very high output MM cartridges might also make it prone to HF overload.. (I place my passive EQ between the first and second stage for this reason.) The high voltage PSU is an odd design, the tube rectifier provides some delay but might otherwise be little more than a fashion statement. The regulator is odd, the transistor in the gate circuit is strange. Unfortunately I am using Google Chrome here at work and it mis-handles the images minimizing them when I click on them so I can't weigh in on what's actually going on as I can't see it clearly enough... IMHO Actual verbatim clones of the Marantz line and phono stages sound pretty mediocre at best. I'm not a fan of the original either.. So with some care and a willingness to hack the board a bit you might actually end up with something decent.
www.kta-hifi.net Last edited by kevinkr; 30th July 2010 at 04:22 PM. |
#5 |
For those interested, BG1 in the power supply, is shown as a K310 (full name 2SK310), the NTE cross for it is a NTE67.
Having never used a 6X4, I hope it likes my single 310-0 tranny. |
#6 |
"Actual verbatim clones of the Marantz line and phono stages sound pretty mediocre at best"
Correct. An early project of mine was a lousy Liteaudio ls7b Marantz 7 clone. Junk. |
#7 |
Right click the images, and open them in a new window/tab for full rez pics.
I'm down with hacking this board up! |
#8 |
Did anyone have recommended modifications to this design?
#9 |
Why not just get an Aikido phono preamp and be done with it?
#10 |
Iv got the board?
| snow48 cheap gigawork "clones" - anybody tried? | Galgo | Digital Line Level | 2 | 11th June 2010 09:37 AM |
| Randy Slone's "Fig 11.4" (Self's "Blameless"?): PCB layout | tcpip | Solid State | 126 | 15th February 2007 04:50 PM |
| PCB DESIGN "PASS" BOSOZ PCB'S ON eBAY | Brad Kizer | Swap Meet | 12 | 4th January 2003 07:41 AM |
| Pics of my diy proac 2.5 "clones" | Kermit | Multi-Way | 71 | 21st November 2002 12:20 PM |
| Page generated in 0.12529 seconds (73.03% PHP - 26.97% MySQL) with 10 queries |
