Circlotron questions - Page 3 - diyAudio
Old 30th August 2011, 09:06 AM   #21
Alastair E's Avatar
Originally Posted by Sk8Ter View Post
I hope you do not mind I have some questions on my HUGE and i mean huge mono blocks..the amp was configured with a 12ax7 voltage gain.. to a 12bl7 driver bootstrapped etc...I thought the amp sounded slow... kinda weird but..anyways I decided to mess around ...did some experimentation on just using the 7199 driving a interstage ..... that did not work. and i dont have a schematic so ...what i am asking ... can someone help me design a good sounding front end to drive the 4.. 2 parallel 6n45c tubes per chanel.....did i mention this thing is a monster!...
Thanks for your help
Difficult to make any recommendations without seeing a schematic to find Exactly How and whats there already!
Is it a circlotron? 6n45c is basically an EL509, so this amp aint THAT huge!
Is this an OTL? or does it have output Tx? Why did/how did you add an Interstage Tx? (A step backwards IMHO, Unless you paid a fortune for the interstage, as GOOD ones are megabux!)
What do you mean by 'Slow'?? Lack of treble? Boomy bass? lack of clarity?--what?
How does a Slow amp sound in comparison to a 'Fast' amp!!
--Like asking how can I improve a cake recipe--Without the recipe to start with!
Blindly chopping/changing components is not the way forward,--no matter WHAT the 'audiofools' say!
Das Beste Oder Nichts
Old 30th August 2011, 04:19 PM   #22
Sk8Ter is offline Sk8Ter  United States
quote: Is it a circlotron? 6n45c is basically an EL509, so this amp aint THAT huge!
here you go sir..
The amp is a circlotron..what i mean by slow is transit response seems slow its hard to describe...that's why i was playing around with interstage (eletraprint) transformers etc.......
I do remember that the man said it was kinda build/designed off of the electrovoice 100a etc..
Please help i would like to get these back up and running..
Old 30th August 2011, 04:34 PM   #23
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Circlotron History Page
electrovoice 100a schematic
Old 30th August 2011, 04:57 PM   #24
Thanks for the link but i seen that and i dont necessarily want to put it back that way..
Old 30th August 2011, 09:25 PM   #25
well, you mentioned electrovoice
but your isn't, since it appears to be pure OTL
but if the builder said electrovoice style, I guess it means circlotron design
I don't how much power you can do with such 4 tubes
maybe on the low side
could it be the reason you feel its a bit 'slow' ?
lack of power ?
or high output impedance maybe ?
could be your speakers have a problem with this ?
maybe you need new tubes ?
and proper adjustment ?
Old 30th August 2011, 09:42 PM   #26
Default No Sir
Look again this is not an OTL..the 2 gigantic tranformers on top ..one is an output and one is a mains transformer...the small trannies inside are the other supplys...it benched at 300wpc.... remember this is mono amp...I have another one..
Lawrence
Old 30th August 2011, 09:47 PM   #27
ahh, ok, I thought about that too, but....
well, then the output trafo appears to be a 'converted' mains power trafo
but 300watt and its not 'just' power consumption you measure ?
Old 30th August 2011, 11:03 PM   #28
No sir 300wpc...the power transformer is sized correctly and to look like the output (symmetry) he winds his own power and outputs!!!
I actually saw him bench it...300wpc! thats why i wanted this monster...super hi quality build....the guy who built this is my friends buddy in WI his name is Joe halser .....but he suggests to just put it back to original etc..but i want to move on to a different/more better topology
Old 30th August 2011, 11:13 PM   #29
smoking-amp's Avatar
I would suggest doing a frequency response test, a distortion spectrum test at low and at moderate power out, and an output impedance test first, before doing any mods. Also determine whether global feedback is used. A schematic would be most usefull too. Then any deficiencies can be dealt with in designing a new front end if required, or just some mods to the existing setup. The 4 6n45c tubes should be capable of 300 Watts. It shouldn't sound "slow" unless something is remiss.
Old 31st August 2011, 05:08 AM   #30
Sir I cannot do any testing until these amps are functional.....hence the reason for posting......anyone have a better working idea for voltage gain and drive?..both have to use 9 pin tubes...so no octal or loctal..etc.
Lawrence
Inductor Circlotron carpenter Pass Labs 27 19th February 2010 06:47 PM
Circlotron Meditations Michael Rothacher Pass Labs 60 4th November 2009 05:04 PM
Circlotron djk Pass Labs 13 20th August 2006 03:19 AM
6C33 Circlotron pat49hk Tubes / Valves 50 26th January 2006 09:06 AM
Supersymmetry Circlotron Circlomanen Pass Labs 6 18th April 2005 06:34 AM
Copyright 1999-2017 diyAudio
