| diyAudio Sponsor | ||
does anyone have a schematic or some advice about rigging up a standby switch in an st70 to avoid cathode stripping when using a SS rectifier?
thanks |
#2 |
#3 |
There isn't much of a problem with indirectly heated tubes...
But you could simply put a low Vdrop tube rectifier in series with the rectified B+, that makes for a slow turn on. Or you can use a thermistor arrangement too... _-_-bear
_-_-bear http://www.bearlabs.com ...ur feeback please - like/dislike my what I have written? PM/email tnx. -- |
#4 |
#5 |
"...to avoid cathode stripping when using a SS rectifier?"
Can anyone explain? |
#6 |
#7 |
apparently, the B+ voltage comes up so fast in SS rectification that the cathodes havent had time to build up a space charge and so cathode damage results. this significantly reduces tube life i am told. makes sense
#8 | |
but there is a full B+ voltage. bias voltage comes up immediately this means that the cathodes are protected from the B+ voltage by the negative bias voltage on the grid? googling this query there are people who have modded the st70 to accomodate SS rectification with a voltage stabilizer tube or something or a standby switch thanks very much Last edited by chopchip; 29th July 2010 at 07:23 PM. |
#9 | |
The negative bias is what keeps the tube from conducting at full max current... It blocks current flow. It is there to regulate immediately. But there will be no conduction until the cathodes are hot anyway. If the cathodes were somehow "blasted" by plate voltage, that would constitute conduction, for any flow to occur. |
#10 | |
joe curcio (manufacturer) says If you search for research on cathode stripping you will find scientific studies (relatively) that find evidence both that it exists and that it does not and consequently I have concluded that empiric evidence needs to prevail. Several points: 1. There are several commercial companies with very sharp experienced engineers producing hundreds (if not thousands) of amplifiers that apply B+ to the tubes (using ss rectification) year after year. I'm thinking that their database should support any evidence for the need to delay the HV for so called cathode stripping if needed. 2. I've designed, built and delivered my fair of tube amplifiers and never have I seen any evidence of cathode stripping. 3. I frequently design SMPS power supplies and from that experience it is clear that that current surges stress components severely (as does excessive voltage and excessive power dissipation) and the suggestion to apply B+ after the filaments have reached temperature makes the cure more hazardous than the perceived illness. These pulse currents are very traumatic to all of the components in the chain (including the power supply, regulators if used and the tubes themselves). To that point however, the inrush current limiter (into the cap bank) has real merit. |
| Cathode stripping in low voltage tubes | engels | Tubes / Valves | 1 | 26th March 2008 04:05 PM |
| Need help to make a correct 83 (merc.vapor.rect) SS replacement. | bembel | Tubes / Valves | 5 | 20th February 2007 04:30 PM |
| Upgrading ST70 PS w/ SS question | zigzagflux | Tubes / Valves | 14 | 23rd October 2006 03:32 AM |
| Doubts on cathode stripping in tubes | teocc_1308 | Tubes / Valves | 37 | 20th May 2006 04:42 PM |
| Page generated in 0.12236 seconds (78.38% PHP - 21.62% MySQL) with 10 queries |
