| diyAudio Sponsor | ||
Ok I looked through numours forums and I am now totally confused. I would like to wire up a 8" LED bar in my 20Watt head and have it controlled by the 6.3v. So my question is this....Should I convert the AC to DC? If so what rectifier (Formula) do I use and what resistor value (formula)and how will it effect the brightness...here is a rough schematic of the connections...
![]() or would I be ok just running it off the AC w/a resistor say 530ohm Here is a link to the LED that I am using...Logisys Computer Inc. any help would be great as I am really getting confused at this point thanks theDogger |
#2 | |
You can get 12V from 6.3V using a voltage doubler (Google: Greinacher doubler) and a suitable regulator (such as LM7812).
mod verb, transitive /mod/ to state that one is utterly clueless about the operation of device to be "modded" and into "fixing" things that are not broken; "My new amplifier sounds great so I want to mod it." |
#3 |
Let me ask a different way what would be the best way to connect the LED light bar so that it is powered by the amp power switch? The current Power LED is run off the 6.3v.
So looking at the spec of the LED bar it already is setup to take 12vDC. So where and how would be the best way to connect it? Do I need a different LED? Sorry but I am really a newbe when it comes to electronics. theDogger |
#4 |
Your 6.3V source will not run the LED requiring 12V dc. If you can access the 6.3V AC source and use a voltage doubler you can get 12.6VDC.
Given that the LED assembly takes 1.5W, you would need 1.5W/12V= 125mA of current. Without full details of your 6.3V source, it is difficult to tell whether or not it could provide this much current. |
#5 |
Ok what info do you need? Or where else can I tap into coming of the transformer? Or would I be better off just making my own LED. Say take 2-3 single LED and wire them in series?
theDogger |
#6 | |
Brgds Bill |
#7 |
#8 |
#9 | |
Yes , 6.3v is almost certainly your heater supplies.
My question is why you want to use it at all. If you must then Arnulf and The Gimp's advice is what I would follow. To be honest I would use a rechargeable battery, or even a wallwort as the led array appears to have a socket for one Good luck Bill edit Quote:
I presume this is a socket
#10 |
Your missing the point...I do not want to hassle w/ a battery and want a clean install. I want to be able to turn the amp on and the LED light up. So my question would be what would be the best way to do this. (For get the 12vLED that I posted earlier.) The current Power LED is connect to the 6.3 so I assume that I can use that for the LED??? How can I do that???
thanks for bearing with me theDogger |
| One bar surround | legendaryfrog | Multi-Way | 30 | 12th December 2006 11:19 AM |
| bar fridge next to subs... | ChesterFuzzin' | Parts | 2 | 17th October 2004 02:47 AM |
| Page generated in 0.10105 seconds (82.11% PHP - 17.89% MySQL) with 10 queries |
