So what you are say is that they may flash on AC?
They will flash to fast to be seen, they will just appear dimmer than normal
How can I test to see if it is AC or DC?
I would imho suggest that you read the sticky thread on safety practices if you haven't already done so.
Will some thing like this work?
Looks OK to me but a second opinion would always be welcome
How do I figure out what I need for a resistor
This might help LED calculator for single LEDs
I would go with the capacitor value and diode series chosen
Brgds Bill
Yes, that circuit with the single diode and capacitor and current limiting resistor works well in this application. I am doing exactly that with the front panel led indicator and an unused heater winding in my latest project.
For resistor value, just google led resistor calculator, there is a plethora of online calculators, and even iphone aps!
Chris
Chris
I must say I hate this kind of discussion in the forum, where everyone points in a different direction!!! Arnulf told the right thing. I only disagree in the regulation with a 7812. The doubler and a resistor to limit current would do the job and be much easier to assemble, being cost effective and reliable.
If you guys read the thread about lighting an LED directly from mains through a 240K resistor only, this one would be really a thesis!!!
All the best,
Max.
All the best,
Max.
You are right, it is not rocket science
I was wiring up an amp this afternoon. It has an illuminated power switch with a built in LED and dropping resistor specified as requiring 12 volts DC. I had a spare 5 volt AC heater winding, so simply used the single rectifying diode and capacitor to get about 6.5 - 7 volts. Works a treat, even though 12 volts specified on switch.
Chris
Chris
There's more than one way to skin a cat
As I happen to have spare bridge rectifiers, caps and regulators etc, I also would have gone down Arnulf and the Gimps road.
However there is a nice simplicity to the method proposed by the Dogger and used by Chrish and welcome having the choice.
Yeah, agreed! Though I have spare regulators, caps and diodes, I am building monoblocks with three regulated supplies per block. Another regulated supply simply to power the power indicator LED looked a bit unnecessary On a previous build I needed about -12V for CCS, so regulated and used the same supply for the same LED indicator switch. If the supply is for a string of effects LEDs, a small regulator circuit is probably what I would do too.
Chris
- Tubes / Valves
- Help wiring up anLED Bar
