| diyAudio Sponsor | ||
I'm trying to figure out if there is a designated name for it's pinout?
I know it's quite similar to a few other pinouts an using the correct pins it's interchangeable, but I find no other tubes in that realm with both pin 6 and pin 9 being G2, my reason for an inquire is I'm cobbling up all the pinouts that when g2 and g3 are strapped to the plate and pin 1 is used for cathode they become pin "compatible", an I'm listing all the pinouts in excel spreadsheet, but I find no designator for the E810F/7788? Are there other tubes with the EXACT same pinout as that E810F/7788, as I find none yet? Thanks, Keg |
#2 |
The D3A is very similar, but missing the G2 grid connection to pin 6.. (Notated as an internal connection, but i have never checked to see what it is connected to..) You could just ignore pin 6...
www.kta-hifi.net Last edited by kevinkr; 27th July 2010 at 10:24 PM. |
#3 |
why bother ?
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#4 |
Yes here are 5 of the pinouts, (referenced to 6EJ7, 9AQ) that when strapping
pin 8 and pin 9 (g2 and g3), to pin 7 (plate), use pin 2 (grid), pin 1 (cathode) they become "compatible" triode strapped pinouts. Compare that to E810F/7788, it will work as well, what I was looking for were there any tubes with that same pinout as an E180F/7788 I may be missing, so I was trying to find out if there was a designation for it's pinout so I may look. Yep D3A an such are on my list. as are 6J52 an 6J9. (rig the heaters 12BY7, 12GN7, 12HL7 could as well) I just haven't seen a designation for the E810F pinout? Last edited by kegger; 28th July 2010 at 01:24 AM. |
#5 |
Woops typo there on that last one.., suppose to be..E810F/7788
| 7788 Triode Curves | dsavitsk | Tubes / Valves | 89 | 21st July 2011 09:27 PM |
| E810F: RIAA circuits | waltube | Tubes / Valves | 8 | 17th December 2007 07:50 PM |
| 7788 tube mic preamp design | rafaro | Tubes / Valves | 1 | 15th February 2006 01:07 AM |
| E810F in triode | cathode_leak | Tubes / Valves | 18 | 10th May 2005 02:56 PM |
| Page generated in 0.08338 seconds (71.45% PHP - 28.55% MySQL) with 11 queries |
