diyAudio Sponsor
Old 27th July 2010, 06:40 PM   #1
Cassiel is offline Cassiel  Greenland
Cassiel's Avatar
Default Looking for oscilloscope recommendations.
A friend of mine needs a scope that can capture 0.1-2Hz signals with accuracy. His budget is tight, so the cheaper the better. Any recommendations that you may have would be greatly appreciated.
Old 27th July 2010, 07:54 PM   #2
What about using a sound card, with high resolution (24bit) and high sampling rate (192KHz)? Probably the cheaper you can find is the E-MU 0202.
About the software, there are many pc based oscilloscope ones, ranging from virtins (Virtins Technology: Turn a PC into Virtual Instrument - Home) to picoscope (which requires his own hardware PicoScope PC Oscilloscope and Data Acquisition Products from Pico Technology) to many others. Try googling "pc oscilloscope".
This one is interesting Visual Analyser 2011
But if he needs also higher frequencies, a sound card based oscilloscope won't be enough though
Old 27th July 2010, 08:00 PM   #3
SY's Avatar
Most of them use cap coupling, so 0.1-2 Hz is going to be a bit of a reach.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 27th July 2010, 08:12 PM   #4
so you have just to remove those caps
Old 27th July 2010, 08:21 PM   #5
jcx is offline jcx  United States
if you know more about the signal properties and can accept PC display you may be able to use a ~ US$100 DAQ module
USB 12-Bit Multifunction Solutions from Measurement Computing
there are also standalone USB data loggers for even less
Old 27th July 2010, 08:47 PM   #6
Cassiel's Avatar
It's for testing a subsonic network at the input of a tube amp. Beats me. Yes, he has a PC.
Old 27th July 2010, 09:37 PM   #7
unfortunantly this won't often work - soundcard ADC usually are single supply and have DC input bias requirement
also the ADC are mostly delta-sigma types with high-pass built in to their hardware digital filters
Old 27th July 2010, 09:53 PM   #8
kevinkr's Avatar
I would think that demonstrating that the filter is at least -3dB at 15Hz and is dropping monotonically below that would be sufficient. Measuring lower than 10Hz with anything other than a DSO is going to be an exercise in frustration.. (Good data acquisition hardware to do this probably is out of budget, but who knows..) Truthfully a good true RMS multimeter may be as useful at these frequencies doing static measurements provided that it has usable response below 10Hz.
My PC based FFT set up is useless somewhat below 20Hz.. (Both comments in post #7 are true IMLE)
www.kta-hifi.net
Old 27th July 2010, 10:42 PM   #9
R.I.P.
Any decent analog scope with a AC/DC input switch can show right down to DC - if switched to DC. A real nasty cheapo may have internal AC coupling, so would be useless.
You can buy a good one new for maybe $500, or get a used HP or TEK scope for maybe around $100 that originally cost $10,000. One with a longer persistance screen would help seeing very LF signals.
Or spend maybe $1000 and get a low priced Chinese made Digital scope - that will do the job perfectly. There's a company that OEM for Agilent (HP), dunno the name.
Fitzing with sound cards etc will just become a hassle, IMO, at the very least cost a lot of time.
Regards, Allen
Old 27th July 2010, 11:43 PM   #10
chrish is offline chrish  Australia
chrish's Avatar
If looking at cheap DSOs, I recently purchased a Rigol DS1052E 50mHz model. It is cheaper than the 100mHz model ($400 vs $600), but is identical. All that is needed is a software hack to convert it to the 100mHz model, see here EEVblog #77 – Rigol DS1052E DS1102E Oscilloscope Hack Update @ EEVblog – Electronics Engineering Video Blog Podcast
New Oscilloscope? joetama Equipment & Tools 12 6th October 2009 01:32 PM
oscilloscope help GeeVee Parts 11 17th October 2007 12:32 AM
Oscilloscope XTAL Parts 0 18th March 2005 05:05 AM
How to use an oscilloscope SimontY Equipment & Tools 15 16th September 2003 10:46 AM
oscilloscope recommendations lowfi Equipment & Tools 16 17th September 2002 05:26 PM
Page generated in 0.11044 seconds (77.62% PHP - 22.38% MySQL) with 10 queries
