diyAudio Sponsor
Old 26th July 2010, 07:03 PM   #1
Default ARC Power source+ 12AX7&12AU7 Pre-amplifier
Has wanted since to design a perfect vacuum tube Pre-amplifier,This time will make a new attempt.
Will use ARC the power source and 12AX7,12AU7 unifies.
Schematic diagram.
Old 26th July 2010, 07:11 PM   #2
Pcb......
Old 26th July 2010, 07:24 PM   #3
DF96 is offline DF96  England
What definition of the word "perfect" are you using? This preamp has too much gain for almost all purposes, runs the 12AU7 at too low a current for linearity, is likely to have a fairly high output impedance due to the unbypassed cathode resistor at the output (in spite of global negative feedback which will help), and may have a noisy input due to the high resistor values at the 12AX7 cathode.
With the signal suitably attenuated to avoid overloading it might add some "tube warmth", but if you remove everything after the volume control it will be more accurate and much cheaper.
I think you need to try again, but bear in mind that most systems don't actually need a preamp at all.
Old 26th July 2010, 08:09 PM   #4
analog_sa's Avatar
The perfect way to put someone off tubes for life i guess. I would rather listen to opamps.
Old 26th July 2010, 08:09 PM   #5
TheGimp is offline TheGimp  United States
TheGimp's Avatar
You will need to make changes to your power supply as it only puts out 210V and your desing is based on having 318V for B+ (Measured on a prototype I presume).
You only have 280V out of the rectified and filtered PS before the regulator.
Old 26th July 2010, 08:53 PM   #6
DougL is offline DougL  United States
Several thoughts. 12AX7 tubes are very linear,if the cathode is attached to a very high voltage or using a good CSS. This also maximises their gain. Since the gain is already more than required, a lower gain tube may be more attractive.
The power supply is competently designed, if uninspired. As it is already pointed out, it is too low for the design as presented.
Have you considered a shunt power supply? It is certainly more fashionable right now, and has technical advantages (and disadvantages) over conventional regulators.
If it were me, and I needed some gain, I would buy an octal Aikido board and use 6SN7GT tubes. If I did not need gain, a Heretical, a B1, or a TVC are all worthy options.
Just my 2 cents.
Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 27th July 2010, 04:56 AM   #7
Thanks everybody's suggestion very much, But the best vacuum tube amplifier, must have good power. This reminds me of the ARC, as shown below.I want to do with this power, should be able to design a more quiet pre-amplifiers.
I will use 300V DC to supply power, but is not 210V.
Old 27th July 2010, 05:09 AM   #8
Continues to draw….
Old 27th July 2010, 05:25 AM   #9
PCB district explanation.
Old 27th July 2010, 06:18 AM   #10
analog_sa's Avatar
Ah, an advertisement. Makes a lot more sense now.
Aikido Phono Amp Output Tubes 12AU7 and 12AX7? JustinJ Tubes / Valves 28 17th August 2010 02:42 PM
12AX7, 12AU7 Substitution Valvomaniac Tubes / Valves 13 22nd March 2007 08:44 AM
12AU7 or 12AT7 instead of 12AX7 ? Gubby Tubes / Valves 5 25th June 2004 11:31 PM
Search for a pre (RIAA+LINE+TUNER)with 12au7-12ax7. bronto64 Tubes / Valves 0 19th April 2004 08:50 PM
Page generated in 0.11115 seconds (79.60% PHP - 20.40% MySQL) with 11 queries
