More Output - diyAudio
Old 28th June 2003, 04:58 AM   #1
Default More Output
I was wondering what was involved in modding my 18 watt tube amp to have a greater watt output?
I really want a 100 watt amp, but I would be happy with 60 or so...
Is this a hard project or could someone with moderate experiance do it?
How much do you think it would cost for me to have it done by a pro?
Old 28th June 2003, 05:18 AM   #2
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Modding an 18W amp to 100W... LOL
Sorry, but you need new iron, new tubes, probably a new driver circuit, basically, new everything. Might as well keep the 18W-er and build a new amp...
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 28th June 2003, 07:17 AM   #3
SHiFTY is offline SHiFTY  New Zealand
SHiFTY's Avatar
What you could try is bi-amping.
Get a big honking solid state amp to do all frequencies below 100Hz and use the tube amp for above 100Hz.
You could use an active crossover which simply splits the frequencies.
You need heaps of power for bass, but not much at all for high frequencies.
Old 28th June 2003, 02:37 PM   #4
316a is offline 316a  England
316a's Avatar
Default Spot on !
Shifty is correct here , if you use an active crossover there will also be more power transferred to the speakers (as speakers internal crossover can be eliminated) plus intermodulation distortion will be reduced . I used to use a 4w a side PP triode amp with 100w a side mosfet amp for >120Hz . Whatever , remember a doubling of power only provides an extra 3dB so you won't realisticly have that much more clout available with a bigger amp
316a
Old 28th June 2003, 09:52 PM   #5
frugal-phile(tm)
planet10's Avatar
Default Re: Spot on !
Biamping can provide an effective 4 x power benefit... if the dividing frequency is approx at the point where the energy above & below the XO point is equal (and the speakers above & below are of equal efficiency), 2 10 W amps provide essentially the same effective power as a single 40 W amp.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 28th June 2003, 10:29 PM   #6
Ilianh is offline Ilianh  Canada
Ilianh's Avatar
Send a message via MSN to Ilianh
Did you want to mean 80 watts?
Did I miss something?
Time is the best teacher; unfortunately, it kills all its students
Old 28th June 2003, 10:33 PM   #7
frugal-phile(tm)
planet10's Avatar
I guess that could get confusing... i meant 4 x the power of a single 10 W amp... but you need 2 of them to bi-amp, so i guess you are getting only 3 dB extra.
But the other benefits (ie driving a less reactive load once the passive XO is removed) and the trend for smaller amps to sound better are what really makes the difference.
dave
Old 29th June 2003, 12:57 AM   #8
diyAudio Senior Member
fdegrove's Avatar
When chosing to go for biamping it's not xtra power your after but the other benefits as Dave correctly points out.
IME it's another step into the FR direction...but not quite.
Nonetheless highly recommended but not without caveats.
Frank
Old 29th June 2003, 08:45 AM   #9
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Default I don't understand this power gain from bi-amping
If I have an ideal crossover (infinite slope), then if the drivers are of equal sensitivity, I must need equal power amplifiers to achieve the same (undistorted) level slightly above and slightly below the crossover frequency.
Yes, it's true that tweeters don't absorb much power - most are rated at <8W continuous. But they need lots of voltage - it's just that the voltage peaks are of short duration, so the power averaged over the thermal time-constant of the tweeter is low.
Where you can get a gain is by noting that many tweeters are 3dB more sensitive than their associated bass/mid, which means you can use an amplifier of half the power for the tweeter.
I agree with all the other statements people have made about active crossover benefits.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 29th June 2003, 08:50 AM   #10
Sch3mat1c's Avatar
Default Re: I don't understand this power gain from bi-amping
Yeah, it would be rather interesting to hook up a signal generator to each, a transformer in place of the speakers, with the amps powered by said transformers..........
I recall Pat Turner saying on rec.audio.tubes that, though it takes less average power (from the narrower bandwidth), it still takes as much *peak* power, because the music peaks are the same, whatever the bandwidth. (Or something like that. Had something to do with white noise too. )
Tim
Difference between SE output transformer and push-pull output transformers hilbert_mostert Tubes / Valves 12 8th March 2009 06:10 PM
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 11:18 AM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 07:15 PM
Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms kelticwizard Everything Else 11 25th March 2007 06:17 AM
I2S digital output in Marantz CD4000 and four TDA1541A with balance analog output iklari14 Digital Source 30 18th July 2003 01:57 PM
Copyright 1999-2017 diyAudio
