diyAudio Sponsor
Old 22nd July 2010, 01:30 PM   #1
neazoi is offline neazoi  Greece
Default Low filament current tubes
Hello,
I need a miniature dual triode type tube like the size of ECC83, but one which uses low filament current. 300mA is too high. the lowest the better.
Do you know of any types?
Great DIY site: http://www.neazoi.com
Old 22nd July 2010, 02:40 PM   #2
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
connect two heater halves in series , fed them with 12V6/150mA
so:
heater - pins #4 & #5 , leave pin #9 unconnected
pins - look clockwise from base of tube
left one is #1
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 22nd July 2010, 03:25 PM   #3
Anyone with even less fillament current?
Old 22nd July 2010, 03:33 PM   #4
Zen Mod's Avatar
ECC83 is already "weak" tube ;
why you need even weaker ..... that will be result of smaller current through filament - whatever tube you find
Old 22nd July 2010, 03:40 PM   #5
Bigun is offline Bigun  Canada
Bigun's Avatar
Lowest filament current - use a JFET. No seriously, they have nice transfer curves and if you are willing to pay, they can be had for use at high voltage.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 22nd July 2010, 04:02 PM   #6
kevinkr's Avatar
Unlikely that you will find what you are looking for in a standard 9 pin dual, but if you are willing to consider some oddball subminis you might find something. Is this as a sub for a 12AX7A (if so you are out of luck) - otherwise you can design something to use some of these submini direct heated pentodes (DHP) instead:
6088 DHP with 20mA @ 1.25V http://www.mif.pg.gda.pl/homepages/f...138/6/6088.pdf
6418 DHP with 10mA @ 1.25V http://www.mif.pg.gda.pl/homepages/f...127/6/6418.pdf
Steve Bench used these in a battery operated pre-amp with reasonably good results. They can also be triode connected.
www.kta-hifi.net
Old 22nd July 2010, 04:53 PM   #7
You could use the tubes designed for portable radios, back in the day. They generally draw 50 mA at only 1.5 V.
Otherwise I think you are stuck.
Old 22nd July 2010, 05:28 PM   #8
I would like the size and look of the glass envelope to be like the ecc83...
are there any lower current versions?
Old 22nd July 2010, 08:33 PM   #9
wa2ise is offline wa2ise  United States
wa2ise's Avatar
There's the 20EZ7, 100ma albeit at 20V. And the pinout is different.
http://www.mif.pg.gda.pl/homepages/f...49/2/20EZ7.pdf
Those DHT submini's tend to be microphonic, however.
Old 22nd July 2010, 09:11 PM   #10
no problem, I need them for computer logic
trade off higher HT current for lower filament current ? Bigun Tubes / Valves 8 27th June 2010 11:10 PM
Filament current bias greenvalve Tubes / Valves 11 29th November 2009 07:01 PM
Current regulation for filament of say a 300B Bas Horneman Tubes / Valves 10 3rd September 2008 10:32 PM
Is constant filament current better way to build amps? Sunsun22 Tubes / Valves 74 21st March 2008 02:40 PM
constant current filament regs Matt Rowland Tubes / Valves 7 25th October 2004 12:12 PM
Page generated in 0.10353 seconds (78.52% PHP - 21.48% MySQL) with 10 queries
