| diyAudio Sponsor | ||
Hello can anybody tell Me if the pin 9 connection on the ECC88 marked (s) is suppossed to be an earth connection??
#2 |
diyAudio Senior Member
Yes, it is an internal shield between the two triodes which can be grounded. Cheers,
Frank |
#3 |
Hello,
If you are going to roll other tubes that have a pinout the same as ECC88 except the 9 pin, you may want to AC ground the 9 pin with a 100 nF capacitor. Other tubes pinout the same except the 9 pin ties to the heater like a center tap between pins 4 and 5. DT All Just for Fun! |
#4 | |
That was a problem once when I ordered 6FQ7s and got 6CG7s instead. The types are otherwise identical, except that the 6CG7s have that internal shield, and the 'FQ7s don't. It's especially bad since these run with the cathodes negative. So I didn't connect the shield to anything, and had no problems doing that. Another potential problem concerned 6DR7s. One sample I have has an "unauthorized" modification: an internal shield connected to the cathode of the large signal triode. That could pose problems if running the opposite triode with a negative voltage on its cathode. You have to watch for stuff like that. Last edited by Miles Prower; 22nd July 2010 at 06:19 AM. |
#5 |
This is interesting. Some tubes which were designed specifically for cascode operation (ECC84 immediately springs to mind) have shield connected to one cathode and it is that cathode that is the upper one in the cascode, meaning that the shield is always at potential at least as high as anode of the bottom stage with regards to cathode of the bottom stage, yet this causes no problems and is so by design.
I hope this makes sense.
mod verb, transitive /mod/ to state that one is utterly clueless about the operation of device to be "modded" and into "fixing" things that are not broken; "My new amplifier sounds great so I want to mod it." |
#6 |
On the ECC84 the shield connects to the upper grid, not the cathode. This is because that will be grounded for AC. I assume this won't upset bias as long as the electrons can't see the shield because the anodes are in the way. I guess there are no anode holes facing the shield?
The same ought to be true for an ECC88. As this has a frame grid almost all the electrons will stay in the narrow space where the anode bends in to be near the grid and cathode. However, to be on the safe side keep it negative - some data sheets insist on this. |
#7 |
You are correct DF96, my memory is faulty !
#8 | |
EDIT: Just answered my own question. I put an ECC88 on my curve tracer and tried hooking the shield up to the anode- it caused no observable change. Last edited by Merlinb; 22nd July 2010 at 05:20 PM. |
#9 | |
Back in 1980: Looking for valves designed for audio only. Back in 1990: What else can we use? Since 2000: Any valve can be used for audio.... Anno 2010: I think I'll use my shot 6080's and recycle them for rectifier use. ... Yeah sure you can use some computer type valves for audio, just don't expect the world of it...... Cheers,
Frank |
| What valves are pin compatible with ECC88 / 6DJ8? | Merlinb | Tubes / Valves | 6 | 31st August 2009 05:12 AM |
| Min 9-pin or 7-pin sockets to fit octal-sized holes? | ray_moth | Tubes / Valves | 8 | 1st January 2008 05:15 PM |
| WTB: dual 8 pin soic to single 8 pin dip adaptors | Spev | Swap Meet | 0 | 13th July 2006 01:21 PM |
| TDA1541A Pin connection question | dsavitsk | Digital Source | 0 | 6th March 2006 09:56 PM |
| What is the 3rd pin for on 3-pin 'lytics? (quick answer needed) | SimontY | Parts | 7 | 5th March 2005 02:10 AM |
| Page generated in 0.11205 seconds (80.69% PHP - 19.31% MySQL) with 10 queries |
