| diyAudio Sponsor | ||
A buddy has a pair of VTL Compact 100 Monoblocks (circa 1988) that have performed well, He recently retubed & reset bias with good initial results. Several weeks later one of the pair began blowing mains fuse. I have SS experience but am a newbie at tubes - my first thought given the age was to replace electrolytic capacitors & check tube associated resistors as well as solder joints & socket to tube pin contact. Am I on the right track or are there other obvious items - also if anyone has a schematic that would be very helpful. Thanks!
Kevin(ahcc20)...I'd rather have a bottle in front of me than a frontal lobotomy!
#2 |
just imagine that amps are SS inside
here are conceptual schematics go with "non powered " route - if you're not 100% sure what are you doing - start from power xformer primaries , measure everything and compare broken channel amp with good one then write here
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#3 |
first of all, you can remove all the EL34 power tubes and check if it blows the fuse. If not, you may check the negative bias voltage to the EL34 are correct. If the -ve bias voltage is correct, you may put a pair of El34 back to the amp....
Have fun. Johnny |
#4 |
Zen Mod & kmtang,
Thanks for the quick replies - will follow your advice & report back (in a few days...I'm on the boat & it's R&R time right now!!)
#5 |
Kevin,
Before digging into the circuit and replacing unneeded parts, I would make absolutely sure the new tubes are not at fault. Regardless of where you got them, if they're new production, they can easily be defective. This is because modern tubes are just not made well anymore. Since you have two amps, swap the output tubes from one to the other and see if the trouble follows. The EL34 tubes are the most likley to fail. Watch them closely in a dimly lit room for signs of glowing grids or overheated plates. Only when you are sure the tubes are not at fault, the negative bias voltage on the EL34 grids (pin 5) should be checked. It will be around minus 30 volts. If one is very off, check the adjustment potentiometers and also the .68ufd coupling capacitors for leakage.
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University |
#6 |
Hollow State,
Thanks - he did try reinstalling the tubes he replaced & the blowing fuse symptom persisted.
#7 |
OK - we spent the morning assessing the fuse blowing amp comparing readings to the good amp. We quickly found the two BY255 diodes on the low side of the B+ supply rectifier shorted. We also measured the resistance from each of the 3 rectifier bridges (B+, bias & filament) downstream & found matching values (within 1%) on the bias and filament supplies between the fuses blowing amp and good amp. The B+ supply value on the fuse blowing amp was about 10% lower than the good amp & when we lifted one side of the 2 shorted diodes the reading agreed within about 2%.
Based on the assessment we ordered replacement BY255 diodes (plan to replace all 4 on the fuse blowing amp & leave the good amp alone). We also ordered replacements for all of the electrolytic capacitors in both amps. We plan to replace diodes & caps on the bad amp & if function is restored then replace caps on the good amp. Thanks for the advice & particularly to Zen Mod for the schematics...fingers are crossed awaiting parts!
#8 |
The parts came in & we spent today installing the replacement BY255s and all of the electrolytics in the problem amp. On power-up it did not blow fuses and all filaments were glowing but a check with signal generator & scope showed output waveform flattened almost to non-existence.
After a few hours of headscratching & comparative readings with the good amp my buddy noticed a resistor in the feedback circuit that apparently got mildly toasted on the diode failure & measured open. We kludged in an array of low power resistors to get the right value and power rating and repowered and the output waveform snapped in right on spec. I'm ordering a proper replacement today and thanks to all for your help and encouragement.
#9 | |
What means the term "typical" ?? Means this term, that the associated circuit was used in exactly the same kind by several other models? In the attachement several pics - not often to find online. Last edited by tiefbassuebertr; 31st January 2012 at 06:11 PM. |
#10 |
exactly - as brought in VTL Book
| VTL MB250 Signature monoblock Manual.. | hifive | Tubes / Valves | 5 | 13th March 2008 12:08 PM |
| Audiolab 8000A - fuse blows | baltazar2000 | Solid State | 1 | 23rd January 2008 09:55 AM |
| Chassis ground blows fuse | krzanik | Tubes / Valves | 51 | 9th May 2007 07:29 PM |
| 2kVA Torroidal blows fuse | ACR | Power Supplies | 52 | 30th July 2006 09:33 AM |
| VTL Compact 100 Monoblock x 2. | sstong | Tubes / Valves | 4 | 17th October 2004 03:49 AM |
| Page generated in 0.12812 seconds (80.90% PHP - 19.10% MySQL) with 11 queries |
