diyAudio Sponsor
Old 21st July 2010, 05:59 PM   #1
losacco is offline losacco  United States
Default 300b driver revisited.
I have built the Walton 300b mono’s with good results. I’m now interested in changing the 300b driver from the 6sn7GB to something else with minimal circuit changes. I have researched past posts and understand this has been talked about a lot. I would need a schematic.
Any new ideas?
Old 21st July 2010, 06:07 PM   #2
kstagger's Avatar
pentode - one stage is all you need. C3m, 6BQ5,etc are alternatives to the classic 91A circuit. Look for the Thorsten Loesch 'Legacy' power amp.
transformer coupling
A nice mosfet follower after the 6SN7 would provide plenty of oomph. Tubelab's Powerdrive comes to mind.
Old 21st July 2010, 09:19 PM   #3
kmtang is offline kmtang  Canada
kmtang's Avatar
I use two stages of 6BX7 to drive the 300B. The plate load is with IXYS45M10 CCS and RC cathode bias. The 1st and 2nd stage is with 0.1uF coupling capacitor.
Johnny
Old 21st July 2010, 09:25 PM   #4
I doubt whether you'd find a tube much better than a 6SN7 unless you go into directly heated tubes.
As said, the biggest improvement you'd make would be to get a pair of something like Lundahl LL1660/5mA transformers for driver to 300b, and direct couple the first half (input) of the 6SN7 to the second half (driver). That's what I'd do with minimal changes. If you have room you might use a grid choke and/or plate choke for the input stage.
Andy
Old 21st July 2010, 10:31 PM   #5
Bigun is offline Bigun  Canada
Bigun's Avatar
there seem to be very few dual triodes like the 6SN7, when I looked around for my project I considered separate tubes for each channel:
6DJ8 and 6N1P - higher mu and lower rp than 6SN7
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 21st July 2010, 11:40 PM   #6
While not necessarily simple, a 6SL7 β follower (see Morgan Jones) into TubeLab's PowerDrive should work out quite nicely. Greater power O/P is available, due to entering mild Class "A2" conditions. A PTFE dielectric cap. (for "maximized" transparency) between the voltage gain block and the MOSFET driver is practical, given the driver's very high I/P impedance.
Eli D.
Old 22nd July 2010, 01:00 AM   #7
tomchr is offline tomchr  United States
tomchr's Avatar
I'm driving a 300B using an anode follower with two 6J5's in it. The anode follower is then followed by a source follower (Tubelab PowerDrive).
If you search for my user name and "anode follower" you should be able to find one of my earlier incarnations of that circuit. I'll get around to posting a current schematic eventually...
~Tom
Old 22nd July 2010, 01:18 AM   #8
CLS is offline CLS  Taiwan
Mine is choke loaded 6S45 direct couple to 300B. Very simple and elegant circuit, but needs a separate (and stacked) power supply for the driver.
Compared to 6S45 spud amp, the sound is very similar, with a sense of - barely noticeable - tiny little bit of light fog.
Has anyone tried a 6S4A as a 300B driver tube? MIKET Tubes / Valves 29 11th May 2012 04:58 PM
pentode aikido driver for 300b dave dove Tubes / Valves 18 24th March 2012 08:37 PM
Looking for non-DRD 300B using D3a as driver jmillerdoc Tubes / Valves 39 14th January 2010 10:40 PM
Low voltage 845SE with 300B driver Ziggy Tubes / Valves 6 18th February 2009 05:16 AM
Using 6L6 for 300b driver papparazzi Tubes / Valves 6 2nd July 2006 08:03 PM
Page generated in 0.10424 seconds (78.55% PHP - 21.45% MySQL) with 10 queries
