diyAudio Sponsor
Old 21st July 2010, 02:33 PM   #1
SpreadSpectrum's Avatar
Default SYclotron schematic
Lately I have been interested in the circlotron circuit. Anyway, some dude on the interwebs put this "SYclotron" circuit on his website. The problem is, only half of it is there. Anyone know where to find the other half?
Old 21st July 2010, 02:38 PM   #2
Speakerholic
Cal Weldon's Avatar
Maybe ask SY if he knows anything.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 21st July 2010, 02:39 PM   #3
SY's Avatar
Hmmm, I'll get around to fixing that one of these days.
In the meantime, here's a link:
Fun little P-P input stage
I've revised the circuit a couple of times and ought to update. The circuit as posted served me well, but subbing LEDs for the cathode bias resistors was a worthwhile upgrade.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 21st July 2010, 02:40 PM   #4
SY's Avatar
My wife will tell you that I don't.
Old 21st July 2010, 05:27 PM   #5
jrenkin is offline jrenkin  United States
Sy, it seems many different tubes could be used in this configuration with only a few adjustments. What are the features that led you to choose the 5691?
I am working on a PP amp that needs a gain of about 15-20 for the front end only and was going to use a long tail pair with a CCS tail using 12AT7 as the input and phase splitter. Gain around 30, so plenty. Are there advantages to your circuit over this? Maybe I will try both.
Old 21st July 2010, 06:00 PM   #6
StevenOH's Avatar
Here is old German Circlotron from '50-'60s. P out is ~20W.
The truth is out there. Who can handle the truth?
Old 21st July 2010, 06:36 PM   #7
SY's Avatar
The 5691 had the right gain for the application (front end for various ST70/MkIII mods), excellent linearity, and low microphonics. Without the transformer, balance is better with higher mu.
I'm unconvinced that my circuit is better than a well-designed LTP in all respects except one; the one area where it is clearly better is input capacitance- it's MUCH lower and provides a better interface for the input transformer.
Old 21st July 2010, 06:56 PM   #8
So without an input transformer, maybe it is a tossup?
Old 21st July 2010, 07:31 PM   #9
SY's Avatar
Without an input tranny, unless there was a really good reason to avoid input capacitance, a CCS-tailed LTP will have better balance than my circuit and would be my fist choice.
Old 21st July 2010, 08:11 PM   #10
Them's fightin' words.
www.buyoutdickvitale.com: Pledge money to enable ESPN to get Dickie V off the air
Linn "LINTO" MC Preamp Schematic without SMPS - Schematic for SMPS wanted tiefbassuebertr Analogue Source 26 5th July 2011 10:22 AM
who s got the best schematic? prorms Solid State 40 24th February 2011 12:29 PM
X.2 Schematic acaudio Pass Labs 1 13th May 2005 07:05 PM
Help with this schematic? imix500 Parts 4 11th August 2004 10:08 AM
What do you think about this schematic? PanzerLord Solid State 9 8th March 2004 06:43 PM
Page generated in 0.12842 seconds (82.31% PHP - 17.69% MySQL) with 11 queries
