| diyAudio Sponsor | ||
I'm trying to fix hum coming from both channels of my diyhifisupply 300B Joplin. The multimeter gives readings of 2.3mV each side and hum is audible through the speakers at 14 feet. Hum should be around 0.9mV
The hum level doesn't change if I turn the volume control nor does it stop if I remove the 6072 and 5687 pre-amp signal tubes. The hum is present with any one of the 300Bs inserted. I'm using short 25g pure silver teflon coated hook up wire for the audio grounds but not twisted or shielded. Have checked all connections and they're good. The ground from the volume control runs parallel with the HT PCB but about 2 inches clear. Rerouting it just makes the hum worse. Can anyone please suggest what I could do to reduce the hum? Would twisting or covering the ground wires with tubular braiding be a good idea? |
#2 |
Hello,
The heater supply can cause hum. How is your wiring? Does the PT give you a CT for the heaters? This ct should be grounded or a vertual ct can be made with two 100 ohm resistors to earth from the heater supply. This is if the heater supply is at fault.... anyway its something to check out. Other than that check your earth connections. Best of luck Mario. |
#3 |
Good evening,
I found in my amp, the power supply was pretty dirty causing a large ripple in my B+ going to the output tranny. There was a consistant level hum until I cleaned it up with a choke and additional filter stage. Good Luck Brian |
#4 |
I was also having humming issues with a 5687 based tube preamp. I managed to minimised the hum considerably by using DC heater voltage. There is however some humming left (not affected by volume control) which I suspect, is caused by B+ ripple.
Will add another stage of choke and/filter stage to see if it helps. |
#5 | |
What frequency is your hum: 50Hz(60Hz) or 100Hz(120Hz)? Can you show schematic of output stage (better full amp schematic)? Do you use linear pots for filament hum level eliminating? Give us some more information and we will certainly find a solution! Kind Regards, Konstantin.
www.Levelfive-Audio.com |
#6 |
Short the 300B grid to ground. If hum presists, post the schematic that shows your filament supply arrangement for the output tubes.
mod verb, transitive /mod/ to state that one is utterly clueless about the operation of device to be "modded" and into "fixing" things that are not broken; "My new amplifier sounds great so I want to mod it." |
#7 |
2.3mV of hum at the speaker from 300B is very normal. Is the 300B with DC filament supply? If it is with DC supply, the hum probably come from the B+ ripple. You can insert an RC B+ filter before the CLC filter to clean up the ripple at the B+.
Johnny |
#8 |
Thanks for all your suggestions. I have attached schematics.
@ levelfive: it sounds more like a constant 100hz hum with an intermittent higher pitch crackling buzz. Have a 47R hum balance pot for each power tube and 22K signal balance pot between each pair. |
#9 | |
Hi User,
Menno van der Veen describes a procedure on his site to adjust an output stage. see: Menno van der Veen, audio electronic research & consultancy, section 'Modify the UL40-S2 into a Super-Triode amplifier.' he describes an interesting find: Quote:
Well just a thought. In my own 300BC project I am working on, I get a hum from the rectifier block - while when I use a tube rectifier (5R4), there is no hum. Annoying. I can trace the hum all the way on the gound plane ( a solid wire) from the first capacitor till the point where it is grounded on the chassis (at the entry point) and there the hum is lowest, or absent. I can hear it on the speaker (very faint) so it is no artifact from my equipment ground wires. It's the commutation spike. albert
#10 |
Thank Triode_Al. I'll read up on this.
| Hum problem | sonata149 | Tubes / Valves | 0 | 28th February 2009 08:35 PM |
| Hum problem | mongiak | Tubes / Valves | 7 | 7th December 2005 07:53 PM |
| say it's a hum problem | resident | Tubes / Valves | 19 | 11th June 2005 06:00 PM |
| Help with hum small hum problem... | Guiness | Tubes / Valves | 10 | 5th May 2003 04:23 PM |
| Page generated in 0.11605 seconds (79.06% PHP - 20.94% MySQL) with 11 queries |
