diyAudio Sponsor
Old 20th July 2010, 04:34 PM   #1
gaffer is offline gaffer  United Kingdom
gaffer's Avatar
Default Ra-100
I am looking for info on building an integrated tube amplifier with off the shelf components, to used in the build. I have been told to look out for the RA-100 as any one any info on this amp?
Old 20th July 2010, 05:16 PM   #2
Stixx is offline Stixx  Germany
Stixx's Avatar
Google
http://dogstar.dantimax.dk/tubestuf/ampindex.htm
Old 20th July 2010, 05:45 PM   #3
Send a message via AIM to DigitalJunkie
I've got one built up from the parts that Fred had left behind,I guess he was planning to build a second "RA-100a" version. I have moved house since building it and haven't had time to pull it out in a while. I still need to set up a proper bench too.
EH EL34's at +600V?
RA-100 Amp pictures by Nothing40 - Photobucket
If you're interested,I can help you out with some of the parts I used,etc. I think I still have a few of the PCB's left also.
One suggestion would be to use a lower voltage power transformer,as you can see the B+ voltage is rather high! ~640Volts in my case.
A while back I had asked Edcor for a quote on a custom power transformer,and it was very reasonable(~$120,IIRC),so I think I'll probably go that route eventually.
One other note,with such a high B+ voltage I had to change the +230V regulator a little. I replaced the bipolar transistor(It was right on the ragged edge of SOA.) with a high voltage FET,and increased the value of the resistor on the zener chain.The zeners would drift as they heated up,and lowering the current through them helped cool them off and keep the voltage more stable.
I changed the pass transistor on the negative (-590V) rail also..I don't remember the part number offhand.The NTE38 that Fred used was hard to find,so I sub'ed in a suitable transistor..I'll find the number if you are curious.
ALESIS RA 100 - Schematics fosforo Solid State 8 16th March 2012 01:31 AM
Alesis RA-100 - may need a new transistor deniss77 Solid State 24 3rd April 2010 09:54 PM
Schematic for Alesis RA-100... Ha! Alesis doesn't have it!! crispycircuit Solid State 0 22nd February 2010 09:16 PM
schematics of Rotel RA-971mk11 / RA-971 digitaldiablo Solid State 0 12th June 2003 04:03 PM
Page generated in 0.08610 seconds (72.03% PHP - 27.97% MySQL) with 10 queries
