| diyAudio Sponsor | ||
I am familiar with loading a transformer by placing a resistor across the + and - leads of the secondary, but I have a preamp in which there are 22ohm resistors in series with each of the + and - output leads, in other words they are between the + out and RCA jack center pin and the - out and RCA ground connection.
What function would these resistors serve? I never see them in any of the schematics I've looked at, and I'm trying to learn why someone would use them? To suppress ringing? What would happen if these resistors were removed and replaced with wire? . Last edited by Magz; 20th July 2010 at 01:27 PM. |
#2 |
post a diagram or schematic?
#3 |
I don't have a schematic I can post right now, but it is a parafeed-type single ended output stage from a 2C22 tube with a DC blocking cap on the cathode. The stock transformer is a small toroidal power transformer (115V+115V, 22V+22V, 0.8VA+0.8VA) with primary DC resistance of 640ohm and secondary DC resistance of 42ohm, 4:1 stepdown.
I'm in the process of replacing the output transformer with a Lundahl LL1674, and I was wondering if I should keep the 22ohm resistors on the outputs, or if I could get rid of them. Also, I'd like to learn a little about what their function is. . |
#4 |
Their function is to waste some power.
mod verb, transitive /mod/ to state that one is utterly clueless about the operation of device to be "modded" and into "fixing" things that are not broken; "My new amplifier sounds great so I want to mod it." |
#5 |
Hi Arnulf, I always appreciate your insightful replies, but can you elaborate a bit, please? Are you saying that they are useless and could be replaced with straight wire? Why would it be necessary to "waste power" at the output of a preamp? To avoid having too much gain? . Last edited by Magz; 20th July 2010 at 02:16 PM. |
#6 |
Sorry, I'm not a native English speaker so I can't explain things very well. Resistors waste power (= "drop voltage") based on their resistance and current passing through them. This is their only electrical function.
There is no reason to waste power at the output of well-designed preamplifier. Then again there is no reason for step-down transformer at the output of well-designed preamplifier (with cathode follower output, no less) either. 2x 22R in series with 10+K isn't much. You really should put together schematic of your preamplifier so we can see what you're dealing with.
#7 |
Thanks, Arnulf.
Since there is no obvious reason why they are there, I'll just remove them and see what happens. Probably nothing. |
#8 | |
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#9 |
Yes, something like parasitic suppression. Or EMI considerations. It's more a precaution than a necessity.
#10 |
Well, I went without the series resistors, and here is a link to the scope results with the new LL1674 transformers:
Grid Stopper Advice - Graphs Included! |
| capacitors in series- what value balancing resistors? | tmhajw | Tubes / Valves | 6 | 20th December 2008 06:19 PM |
| current sensing in series with anode resistors | ErikdeBest | Tubes / Valves | 9 | 7th March 2007 10:26 AM |
| Info on Resistors / series resistance | one1speed | Full Range | 7 | 24th February 2006 01:29 PM |
| resistors in series | starrman93306 | Car Audio | 6 | 8th November 2004 08:56 PM |
| Are the outputs in the X series amps socketed? | Apogee | Pass Labs | 2 | 23rd September 2002 10:35 PM |
| Page generated in 0.10433 seconds (79.62% PHP - 20.38% MySQL) with 10 queries |
