How to get the best out of the 6C33C-B? - Page 2 - diyAudio
Old 21st July 2010, 02:48 PM   #11
djn is offline djn  United States
djn's Avatar
OK, I can't seem to attach in a PM either. If you email me at djnagle@comcast.net I will send you the writeup. Cheers.
Old 21st July 2010, 08:50 PM   #12
How about uploading it to rapidshare or something?
Old 23rd January 2013, 08:27 PM   #13
noge is offline noge  New Zealand
Did anyone finish their 6C33 amp?
I'm quite interested in this tube but can't decide whether to go PP or SE, OTL or use an output transformer. Any opinions greatly appreciated.
Old 24th January 2013, 05:29 AM   #14
SVStube is offline SVStube  Ukraine
1579 is the equivalent of 6SL7, equivalent 6P9 - 6AG7. Later in the first stage has been tested ECC81 and ECC85. It made the sound much better.6S33S with the usual fixed bias can not be used: plate current is often increased without control at constant voltages of the grid.Therefore, to make the management bias with a simple transistor circuit.
Old 25th January 2013, 04:31 PM   #15
dekiller's Avatar
If I want to build a 6C33C amp, it must be OTL. Just not sure which circuit has best performance and stability.
Old 26th January 2013, 10:39 AM   #16
Zibi is offline Zibi  Poland
Originally Posted by knightsound View Post
My design goals are straightforward:
- One 6C33C-B per channel, single-ended operation
- 15-20W @ < 1% distortion
It is impossible.
Old 26th January 2013, 11:07 AM   #17
azazello's Avatar
I made 2 SE 6S33S for my friends, according Russian schematic with 6E5P, I tried with E280F-Phillips and sound was better:
http://sergeev21.narod.ru/6s33s6e5p.GIF
https://picasaweb.google.com/1095707...98640803460258
https://picasaweb.google.com/1095707...84404731452706
Old 26th January 2013, 07:49 PM   #18
Ketje is offline Ketje  Belgium
Ketje's Avatar
Some time ago I got also interested in that 6C33.The huge amount of power compaired to the output was a bit too far out for me .
Perhaps someone can play with what I imagined,so here it is.
Mona
Old 26th January 2013, 09:25 PM   #19
Nice amp!!!
Is it possible to "adapt" this schematic to use headphones? e.g Zana Deux (on this case the Zana is an OTL amp)
Cheers.
Old 26th January 2013, 10:47 PM   #20
FullRangeMan's Avatar
Wow, This is the best chassis I have see today, large metal table for heat disspation and thick wood sides for filter trafo ressonance.
Congratulations
>Never go to a psychiatrist, adopt a cat or dog from the streets. On the streets pets live only two years average.
6c33c-b & 6c33c-v skybird Tubes / Valves 4 21st April 2009 06:21 AM
6C33C-EB / 6C33C-EV extended life ? ger56 Tubes / Valves 2 14th October 2007 05:54 PM
How to make this 6C33C better?? imagine Tubes / Valves 7 16th February 2005 04:25 PM
6c33c-b Se morfeas Tubes / Valves 3 19th November 2004 11:55 AM
6c33c Question woody Tubes / Valves 1 17th May 2002 12:01 PM
Copyright ©1999-2017 diyAudio
