diyAudio Sponsor
Old 20th July 2010, 03:57 AM   #1
SpreadSpectrum's Avatar
Default TO-220 PCB spacing for HV MOSFETs
I am getting ready to design a board for a tube circuit and am planning on using FQPF2N90 as source followers to drive some tubes. I could potentially have almost 800V from drain to source and am a bit worried about the spacing between pins of the TO-220 package. Spacing between exposed traces (the solder holes) will be about 40 mils.
I have read on the 'Net that breakdown voltage between exposed traces across FR4 is 40V/mil. This gives about 1600V, a margin of 2:1. However, most sources recommend having much more spacing than this for these voltage levels. I am probably going to conformal coat these if it will help.
I guess I am looking for a warm fuzzy like, "Yeah I do that all the time and have no problems." Anyone else use HV TO-220 MOSFETS on PCBs in tube circuits?
Old 20th July 2010, 05:07 AM   #2
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
If you don't feel comfortable with it, you could edit the footprint to stagger the pins, or spread them out (or use a TO-247 sized footprint instead).
I've seen slots carved in the board around high voltage transistors, too.
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 20th July 2010, 05:18 AM   #3
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
I use for 400V stabilizer, from 800V B+. It sees all 800V DS voltage when switched on. No special measures used: no slots, no coating. Just legs arranged in a triangle.
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 21st July 2010, 02:09 AM   #4
I think I will spread leads a bit. TO-247 looks like a good lead spacing to use, thanks Tim.
Old 21st July 2010, 02:24 AM   #5
jcx is offline jcx  United States
the package/lead spacing itself doesn't meet several common standards for creepage, clearance distance at the rated Vds
I plan on coating the lower body, leads, and pcb - and lead forming for larger pcb pad clearance when using TO-220 with 600 V
that doesn't mean other people don't ship smps that violate those standards
Old 21st July 2010, 12:24 PM   #6
Ian444 is offline Ian444  Australia
You can spread the legs, but the 3 stubs coming from the TO-220 package before you do the leg-spreading is where the action might happen, or not. Conformal coating will help reduce arcing under moist or humid conditions. Consider it takes 16,000V or so to create a good solid spark across a 0.030" gap (spark plug). 0.030" = 0.75mm.
Old 21st July 2010, 02:30 PM   #7
Yeah, I'm kind of frustrated that they don't use a different package for a 900V Fet. It has really low Crss, though. 5.5pF
Old 21st July 2010, 05:17 PM   #8
tubelab.com's Avatar
OK, I'll say that. In truth I have only been to 650 volts. That's the end of my power supply knob.
I would assume that you are referring to a professionally made PC board with a solder mask coating. The home made stuff that is etched in ferric chloride does have stray copper particles and ionic contaminants all over and imbedded into the surface. Add some south Florida humidity and some fireworks should happen.....but it hasn't yet.
I did find some nice TO-247 Fuji mosfets on sale at Allied last year. I will probably use them in big voltage experiments, but my TO-220's havent blown yet.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 21st July 2010, 05:33 PM   #9
Did it Himself
richie00boy's Avatar
I have pondered this quite heavily in the past.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 21st July 2010, 05:51 PM   #10
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Air breakdown is around 15,000V per inch depending on humidity.
I measured the lead to lead distance of a TO-220 at 0.060, so the breakdown is around 900V not counting creepage. Then there are those SMT parts like TO-252 where it is closer to 700V.
I think there is a need for a new package (and leadframe) for the HV parts. The only parts I see in TO-247(AD or S) are high power devices.
They really need to get rid of the drain off the leadframe and just have the gate and source coming out the lower body with the tab as the Drain. (This wouldn't work on an Isolated-Tab package.)
Looking for recommendations on TO-220 package GSD (Hitachi) pin-out MOSFETs BoilermakerFan Solid State 1 21st May 2010 04:43 PM
PCB track spacing (HV) keyne Parts 3 1st November 2004 04:57 AM
100kHZ HV Mosfets recommendation CV Solid State 10 11th March 2004 09:22 PM
Page generated in 0.11075 seconds (77.50% PHP - 22.50% MySQL) with 10 queries
