| diyAudio Sponsor | ||
I recently obtained some 12AU7s for my preamp. Some Mullards from Blackburn and Funkwerks. The funny part is the FunkWerks tubes when the preamp is switched on - they flare up like a lit match for a second at two points on the base, before settling down.
Is something wrong with these tubes? Like slight leak in vacuum or something? They sound superb though! Very musical with great top-end!! Thanks for any advice. |
#2 |
These are the heaters. There is often a flare as their cold resistance is lower than when at running temperature so they will draw more current. This will reduce as they heat up. Nothing to worry about.
#3 |
Sadly I have had a couple of NOS Mullards (12AX7A/12AU7A) burn out in a relatively short time frame due to uncontrolled cold inrush current, this is a particular problem if the filament supply has a very low source impedance. Based on my experience I would recommend an NTC thermistor to limit the initial inrush current to a safe value.
www.kta-hifi.net |
#4 | |
![]() My Mullards, or BEL or Shugangs or JJ/Teslas dont flare up, only the funkwerks do. For a few seconds actually. When I switch off and switch on immediately, it doesnt happen... So I am thinking (or want to believe) like Bone said, "nothing to worry about" . However perusing your line of thought, NTC thermistor - part number (edit: ok google was easy, but are there different parts/ratings for different circuits ) ? where in the circuit do I place them? I am only a solder specialist and a dud at electronics. Can I copy the circuit schematic so you can tell me where? Anything that might potentially increase the life of my precious toobs Cheers Thanks. Last edited by Gobble; 19th July 2010 at 06:55 PM. |
#5 |
NTC thermistor in series with primary will help.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#6 |
Or even better, CCS heater supply.
mod verb, transitive /mod/ to state that one is utterly clueless about the operation of device to be "modded" and into "fixing" things that are not broken; "My new amplifier sounds great so I want to mod it." |
#7 |
Or a voltage stabilizer with current limit.
#8 | |
Need a little more information, my preference is for DC heating with a CCS or current limited voltage regulator. (Limit current to about 10% greater than the required current.)
www.kta-hifi.net Last edited by kevinkr; 20th July 2010 at 12:36 AM. |
#9 |
Hello All,
I use GE sensing CL-90’s from Digikey. These are used in series with the primary winding of the transformer. IIRC this device has 120 ohms cold and 9 ohms when warmed up. DT All Just For Fun! |
#10 |
Is Funkwerks a manufacturer? I'm not familiar with that name. If they are not a manufacturer it is possible that the flashers are the ones that are "supposed to" flash, no?
I have a Zenith branded Blackburn Mullard 12ax7 that flashes, and it does so with pride. |
| The daunting world of tubes (where to start) | Marko25 | Tubes / Valves | 38 | 11th March 2009 10:28 PM |
| Soft Start for Tubes | Bengali | Tubes / Valves | 4 | 27th December 2007 05:36 PM |
| What's the start current for fluoroscent tubes? | Christer | The Lounge | 4 | 9th April 2004 09:37 PM |
| include flare in flare ports? | psychokids | Multi-Way | 1 | 20th April 2003 05:32 AM |
| I'd like to start with tubes. | JoeBob | Tubes / Valves | 5 | 9th March 2002 03:15 AM |
| Page generated in 0.11715 seconds (78.88% PHP - 21.12% MySQL) with 11 queries |
