diyAudio Sponsor
Old 18th July 2010, 05:43 PM   #1
807tubenut's Avatar
Default Wanted! single-ended 807 schematic
Found a nice little 10w output tranny digging in my work shop Friday, Got my gears going to make a single 807 amp for my jukebox, It's built in amp was "misplaced" a few years back.
Thanks!
Old 18th July 2010, 06:37 PM   #2
What aboutthis one.
Very good and simple.
I use this amp for years.
Triode Dick's Page
Projects/807SE
All the best,
Hans
Old 18th July 2010, 06:40 PM   #3
llwhtt is offline llwhtt  United States
Gordon Rankin did an SE807 design article back in the 90s for Sound Practice magazine. If you google you can find all of the Sound Practice magazines.
Craig
Old 18th July 2010, 08:21 PM   #4
Thanks!
Take a look at Alex Kitic's RH807. I am in the middle of a rebuild with 6L6GC, only change I would advice is to use a stabilised voltage for g2 since his solution is adviced against in one of the tube manufacturer's literature. His RH84 is well regarded and has been built multiple times.
Depending on your listening preferences you may want to use either a 12AT7 or 12AX7 as driver.
AM
Old 19th July 2010, 03:38 PM   #5
807tubenut's Avatar
Thanks guys!
Love the RH807, one Q, will my speco T-7010's be ok for OPT's?
specs are as follows.
70 volt, 10w
4 and 8 ohm out's
the 10w input is 500ohm
Old 19th July 2010, 04:21 PM   #6
Arnulf is offline Arnulf  Europe
Of course not.
mod verb, transitive /mod/ to state that one is utterly clueless about the operation of device to be "modded" and into "fixing" things that are not broken; "My new amplifier sounds great so I want to mod it."
Old 19th July 2010, 04:23 PM   #7
Michael Koster's Avatar
Thanks guys!
70 volt, 10w
4 and 8 ohm out's
That sounds like a line matching transformer, which for 2 main reasons isn't suitable for a SE OPT for an 807
- not gapped for DC
- 500 ohm impedance on primary is too low, even if you derate to 5W and load the 4 ohm tap with 8 ohms.
michael
PS maybe a 6080 parafeed circuit could use this transformer
Old 19th July 2010, 06:17 PM   #8
807tubenut's Avatar
Any idea what the specs on the RH807 OPT's are? or a location to buy them?
Old 19th July 2010, 06:56 PM   #9
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Sure. Parafeed cathode follower loaded on CCS would sing nice.
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 19th July 2010, 08:57 PM   #10
Thanks guys!
70 volt, 10w
4 and 8 ohm out's
5 ~ 6 k primary, 60 mA ~ 80 mA, 7+ watts. I picked the James 6123HS which is overkill but gives flexibility to try out different tubes / configurations if I fancy that at some time in the future. (unlikely).
AM
Are there Sugden (Sugdenaudio) Single ended power stages? Schematic wanted tiefbassuebertr Solid State 1 1st March 2010 06:38 PM
807 single ended guitar amp phuc-u.com Tubes / Valves 1 8th June 2008 07:52 AM
Single Ended, Single driver: In-room distortion measurements Gerrit Boers Full Range 4 27th November 2007 08:12 AM
Anyone play with the Zen Single-Stage Single-Ended Class A? Rino odorico Pass Labs 13 29th August 2002 09:01 AM
Page generated in 0.10954 seconds (88.78% PHP - 11.22% MySQL) with 10 queries
