| diyAudio Sponsor | ||
hi,
i get intermitent static popping sounds from the speakers when i have the st70 plugged in. is it some bad solder joints? i dont think i had the problem when i first started listening to it. any ideas? thanks |
#2 |
That sounds typical of intermittent contacts with tube pins. A hissy pop. Wiggle the tubes a little and see if you get more or less. Be gentle on the board tubes so you don't crack any weak solder joints under those sockets. It could also be bad solder joints already on those, mimicking a dirty socket. Inspect those joints closly with a magnifying glass and reflow them if you have any doubts. I'd do that first just to eliminate any obvious bad joints. You will probably find some some wrinkley, dark, solder and that is usually the source of trouble and should be reflowed. Be quick and add a dab of new solder to help the old flow better. You could also be hearing noise from leaky caps reforming if this is an unused amp.
BTW, diytube.com has a dedicated st-70 section. Last edited by 20to20; 17th July 2010 at 11:13 PM. |
#3 | |
thanks for the reply. ill reflow those joints. but now i have blown ANOTHER gz34. if i turn the amp off and on and dont wait for at least 30 seconds i blow a fuse and even then the rectifier gets damaged so that the next time it happens it is ruined and shorts out, sparks and dies. this is 3 rectifiers now! arrgh any advice? sigh |
#5 | |
thanks again! |
#6 |
I have read that silicone diodes (eg UF4007) in series with the plates on the valve rectifier can help reduce the arcing/blowing. I did this on my latest project. There are generally plenty of spare pins on the socket to place the silicone diodes, so it is an easy mod.
| Speakers popping and static noise at all volume levels PPI Amp | duderino201 | Car Audio | 21 | 8th May 2010 09:19 PM |
| Rogers pops, crackle and static are driving me mad! | cr0wl3y | Tubes / Valves | 14 | 8th March 2010 11:23 AM |
| Mains pops and clicks | markiemrboo | Chip Amps | 10 | 9th September 2007 09:57 AM |
| Amp pops on power down? | jjai | Instruments and Amps | 2 | 8th March 2005 08:26 PM |
| Static in my screen make sound in my speakers :( | Guss | Everything Else | 4 | 7th March 2004 11:21 PM |
| Page generated in 0.09659 seconds (78.40% PHP - 21.60% MySQL) with 10 queries |
