diyAudio Sponsor
Old 17th July 2010, 01:54 AM   #1
cbj591 is offline cbj591  United States
cbj591's Avatar
Default NFB Clarification
Good evening all,
I wanted to get a clarification on how to tell if I have positive or negative feedback.
I have a 500k pot in my feedback loop. when I increase the resistance, the volume increases. That is positive feedback correct? If so, can I swap the two wires coming off the preamp tube going to the PI caps to correct this?
Also, thanks to everyone for helping me learn the do's and dont's of component placement. My hum issues are pretty well gone.
Special thanks to Azazello, if I wouldn't have added the choke to the power supply that he suggested, I would still have a nasty low level hum from the simple/dirty power supply.
Thanks again
Brian
Old 17th July 2010, 01:58 AM   #2
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
No.
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 17th July 2010, 02:31 AM   #3
cbj591's Avatar
By no, I can assume that it is negative feedback and everything is connected correctly.
Thanks again
Brian
Old 17th July 2010, 03:03 AM   #4
Wavebourn's Avatar
Yes.
Old 17th July 2010, 03:09 AM   #5
cbj591's Avatar
Thanks so much Wavebourn, I just wanted to make sure I didnt phrase my question in a way that seemed like I was asking or implying the wrong thing.
BTW - Nice site you have.
Old 17th July 2010, 03:28 AM   #6
Wavebourn's Avatar
Thanks.
In case of positive feedback you would turn your amp into sound oscillator.
Old 17th July 2010, 04:10 AM   #7
cbj591's Avatar
Originally Posted by Wavebourn View Post
Thanks.
A sound oscillator would be a nasty buzzing/pulsing sound coming out of the speakers? If it is, then i'm in good shape. Just a little distortion on the top end.
Sorry for all the questions, I'm trying to absorb all the info I can
Old 17th July 2010, 06:18 AM   #8
Wavebourn's Avatar
Don't be sorry.
If amplification factor through the loop of positive feedback is a little bit greater than 1 on some frequency the amp starts oscillating. Think of it as if signal from output coming back to input is amplified, this amplified signal comes again to the input, is more amplified, and so on...
Old 17th July 2010, 01:47 PM   #9
jrenkin is offline jrenkin  United States
Just to state in clearer terms than "yes" or "no"
when you increase resistance you are reducing the feedback signal, so if the volume increase with reduced feedback signal, it must be negative feedback.
Obvious to knowledgeable folk live Wavebourn , but I always have to think it through literally
Old 17th July 2010, 02:17 PM   #10
DF96 is offline DF96  England
This assumes that the pot is in series with the loop, not paralleled to ground - this would have the opposite effect!
Changing volume via a feedback loop can lead to oscillation at low volume, because this is when the loop gain is at its highest. Is this just a pot during tuning, to be replaced by a fixed resistor once you are happy with the design?
An attempt for clarification. Lumba Ogir Solid State 1 4th March 2009 07:46 PM
Feedback Question/Clarification fizzard Solid State 256 25th December 2007 05:21 AM
PPP OPT clarification PeteN Tubes / Valves 13 2nd November 2007 06:20 PM
Newbie needs clarification MlinarS Tubes / Valves 5 9th February 2005 03:02 PM
Page generated in 0.08966 seconds (87.16% PHP - 12.84% MySQL) with 10 queries
