diyAudio Sponsor
Old 15th July 2010, 11:13 PM   #1
Default Bias Curves
I am designing a fixed bias, EL34 Push-Pull amp which will have an HT of 350VDC
for sake of argument, I'll pick 325VDC for the screen grids.
Can anyone tell me what the formula is to work out the Bias Voltage (Vg1) for different anode and screen grid voltages.
Similar to the first 3 graphs in this datasheet,
HTML Code:
http://www.drtube.com/datasheets/el34-philips1969.pdf
Thanks,
Oliver
Old 16th July 2010, 06:16 AM   #2
Arnulf is offline Arnulf  Europe
There is no formula, the curves are obtained empirically. EL34 is extremely well docummented so you should have no problems finding multiple datasheet for it.
mod verb, transitive /mod/ to state that one is utterly clueless about the operation of device to be "modded" and into "fixing" things that are not broken; "My new amplifier sounds great so I want to mod it."
Dynamic Bias - Active Bias - Automatic/Self biased - Overview wanted tiefbassuebertr Pass Labs 11 5th May 2011 08:42 PM
Changing grid leak bias preamp to cathode bias bereanbill Tubes / Valves 8 28th March 2009 05:26 PM
Stray hum pickup *preamp* cathode R-bias vs. battery bias & 12AU7vs.5687 awedio Tubes / Valves 2 19th April 2008 01:30 AM
Derive Triode Curves from Pentode Curves? dsavitsk Tubes / Valves 3 14th May 2007 06:10 PM
Supressed bias amplifier, automatic variable bias system. destroyer X Solid State 2 20th September 2004 10:24 AM
Page generated in 0.06866 seconds (66.03% PHP - 33.97% MySQL) with 10 queries
