Drawing schematics?
AX tech editor
Joined 2002
Do you want only to draw nice schematics? Or are you thinking about designing PCBs for your circuits? If that is the case, you should take a schematic program with the capability to generate netlists, which can then be read by the PCB program. That way, you are sure that the PCB is exactly like the schematic.
Jan Didden
diyAudio Senior Member
Joined 2002
The schematic program with the smallest learning curve is Tubepad . This is a library of images for use in MS Paint - so it's childs play to learn... and almost as quick as a pencil and paper once you have used it a few times.
So do I.
I've converted all the *.bmp files to *.gif though.
This gives me much better results ( no pixelation black spots) and the endresult takes up a fraction of the HD/WEB real estate.
Cheers,;)
