Max power output chart for SE and PP
Old 27th June 2003, 06:18 AM   #1
ashok is offline ashok
ashok's Avatar
Default Max power output chart for SE and PP
I am reposting this because the previous heading does not indicate the real subject.
Is there any chart on the web that lists out the maximum power available in SE and PP mode from the following tubes.
2A3
6L6
300B
EL84
EL34
Thanks.
Ashok.
AM
Old 27th June 2003, 06:38 AM   #2
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
EL84 - SE ~6w, PP up to 17w within ratings (AB1)
6L6 - ~10W tops in SE, and then up to about 60w in PP (for 6L6GC.. i think only about 35w with 20w versions.)
EL34 should be kinda similar to 6L6.. similar class of tube
2A3 is something like 3...4w in SE
Old 27th June 2003, 08:18 AM   #3
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
EL34 can go up to 100W in class B with 800V on the plates...
You're more likely to find it around 5W SE or 30 to 50W PP.
As I recall, 2A3 is around 5W, 300B 8...
Of course, no tube is really limited. Depending on how short the test is, you could go with a dirty class C PP amp with some pretty damn severe drive, voltage and current levels, and push say 5 or 10 times as much power from any of them...
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Max power output chart for SE and PPHide this!Advertise here!
Volume Displacement For SPL Chart kelticwizard Multi-Way 12 24th November 2013 09:58 PM
NRI 70 tube chart lightguy Tubes / Valves 1 18th November 2007 12:15 PM
Impedance Chart? angsuman Multi-Way 8 22nd May 2006 11:03 PM
power output calculations, rated power and required power output metebalci Tubes / Valves 7 22nd February 2004 05:49 PM
Seeking 6AQ5's Curve Chart Kenneth Zhu Tubes / Valves 17 4th October 2003 01:55 AM
