Using SE OT for PP.
Using SE OT for PP.
Old 15th July 2010, 10:44 AM   #11
triode_al is offline triode_al  Netherlands
triode_al's Avatar
Hi Stalker,
on some Hasimoto circuit I saw a SE output used for push-pull. The four primaries had a tap such that it gives two sections on both sides. The SE impedance is 3k5; the Raa wil then also be the same, 3k5.
Then what is the impedance of the "tap"? This is 2k5, as this is the 3k5 divided by 1,4 [2 square root].
What I see in your example does not fit this logic!
In the described circuit, 2x 2k5 is admissible for a 300B for instance.
SPU --> tube MM/RIAA;
Pass buffer -->300B SE Anza´ Za´ka; --> FE103 sigma TQWT
Using SE OT for PP.Hide this!Advertise here!
PP transformer for SE use Brian Donaldson Tubes / Valves 45 11th January 2006 08:16 PM
SE UL OT - primary wired in reverse benny Tubes / Valves 0 29th May 2004 04:10 PM
SE or PP? kmj Tubes / Valves 16 30th April 2004 05:21 AM
SE used as step down OT redofneck Tubes / Valves 2 7th March 2004 07:26 PM
SE vs. PP stigla Tubes / Valves 17 6th June 2002 02:40 AM
