Odd/Crazy output transformer design? - Page 12 - diyAudio
Old 18th September 2012, 10:07 AM   #111
analog_sa's Avatar
Originally Posted by xpl1c1t View Post
This makes it quite an easy task.
Why?
Old 18th September 2012, 10:20 AM   #112
AJT is offline AJT  Philippines
AJT's Avatar
Before i read this post I was going to drop the idea of hand winding a toroid output transformer simply because it would be too painstaking to get those hundreds/thousands of feet through the damn donut hole every wind.
This makes it quite an easy task. Thank you linuks!
you need something like this...shuttle can be made of plastic or wood, must pass thru the hole of the core....good luck.....
the best advertisement for a good audio design is the number of diy'ers wanting to build it after all the years....never the say so of so called gurus....
Old 18th September 2012, 10:23 AM   #113
AJT's Avatar
Originally Posted by pieter t View Post
Please note that progressive winding to lower layer to layer capacitance only tackles one of the capacitive components in a transformer.
The primary by itself also has a capacitive component, the longer the wire the more capacitance.
Therefore choosing a big core with "little" copper is IMHO always better than a small core with "much" copper (apart from nowadays catastrophic copper prices!).
With the big core / little copper combo the lower capacities and DC resistances (copper losses) make better transformers.
thanks, will keep this in mind.....
what is the downside for not utilising the full winding window?
PP Output Transformer design Hi_Q Tubes / Valves 12 28th October 2009 03:23 PM
Output transformer design for SS amp Tyimo Tubes / Valves 12 17th January 2007 02:02 PM
odd transformer design godfather_cz Parts 7 3rd May 2003 11:32 AM
Crazy transformer? Lisandro_P Everything Else 4 5th January 2003 05:54 PM
Output transformer makes odd whining noise tr3 Tubes / Valves 5 23rd June 2002 08:11 PM
Copyright 1999-2017 diyAudio
