| diyAudio Sponsor | ||
I am finishing a point to point SimpleSE build and I noticed there is no smoothing cap after the 10k that supply's the 10m45. I am not well versed in silicon so I ask; Is this cap not needed in this implementation? Is there no voltage swing over the resistor because the current drawn is constant? Will the addition of a cap make life easier/harder on the 10m45? Thanks for the assistance of a sand novice!
#2 |
Hi mctavish,
Do you mind posting the schematic? It is much easier to understand your question. Thanks, Johnny |
#3 |
I believe you are talking about the TubeLab's Simple SE amp.
The 10K resistor works like a protection for the 10M45 CCS that does not require bypass capacitor at all. The dynamic resistance of the 10M45 that provides excellent power noise rejection. Johnny |
#4 |
Not having looked at the schematic I suspect the resistor is there primarily to reduce dissipation in the 10M45..
www.kta-hifi.net |
#5 |
Thanks for the replies. Yes, the amp is Tubelabs simplese. I am doing a p2p version.
#6 |
Mctavish if you get a chance throw up some photos of yours, especially of the point to point work.
- Nic |
| 10m45s LTspice model | dave slagle | Tubes / Valves | 10 | 19th October 2011 04:37 PM |
| 10M45s: strange behaviour @ 100mA | pauldune | Tubes / Valves | 61 | 4th March 2010 11:02 PM |
| Ixcp 10m45s | Wombat 397 | Tubes / Valves | 14 | 4th September 2009 12:09 AM |
| Help needed with 10M45S integration . | TugaTweaker | Tubes / Valves | 11 | 9th March 2009 07:33 PM |
| Wtb; 10m45s | Cobra2 | Swap Meet | 9 | 26th November 2008 05:17 AM |
| Page generated in 0.07997 seconds (73.07% PHP - 26.93% MySQL) with 10 queries |
