| diyAudio Sponsor | ||
Hello everyone,
I tried to design an output stage for my TDA1541 dac using a D3a. Well, not really designing this time (my second), I got most of it from the data sheet.. But I couldn't completely copy it, as some values aren't mentioned.. ![]() The troublemaker here is R6, I haven't got a clue how to determine this one, couldn't find it in my books.. Also I chose 1K for the gridstopper R2, but it's kind of a guess.. Designing this stuff is quite new to me, I'm terrible at maths but I'm eager to learn. I'm sure posting this here will get me some usefull extra info. All comments are very welcome! Thanks in advance! |
#2 | |
Usually, a value around 100k-470k is enough. Grid stopper is commonly using 1k, carbon composite (like AB, Riken, Takman TRex), or Tantalum (AN, Sinkhoh). Can be ranged from about 200 ohm or up. Lower value may increase a possibility to self-oscilate(unstable). But the higher, may make high freq roll off. Another comment, Input Coupling 100nF may be to small (to high of low freq roll off), as the grid leak is about 47k. I like about 1uF (PIO or good MKP), or bypass it as long as there is no DC offset from previous stage. Thanks, Ervin L |
#3 |
#4 |
BTW, I'll be using a very low value I/V-resistor, I'm not quite sure if the operating point is best suited for this. I was looking at the curves, and liked the -0.5V line at around 95V and 30mA.. In the end I decided the TFK guys probably knew their stuff a lot better than I do.
http://www.hifitubes.nl/weblog/wp-co...funken-d3a.pdf |
#5 | |
#6 |
I've done some experiments before, started with 100 ohm as suggested on Lampi's website, went lower step by step and settled with 28 ohm if I remember correctly. 100 ohm is waàày too high btw, you get a nice distortion 'sauce', and a decent output voltage, but it's very much 'my-fi'..
I believe some people even used 18 ohm.. |
#7 |
C2 is the wrong polarity.
Should be positive end to cathode.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#8 |
#9 |
Isn't the plate resistor way too low in value? If you don't have more B+ for the stage I would recommend a CCS or gyrator instead of that 625R thing (which is about 1/4 of the D3a internals resistance, when triode connected).
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY! |
#10 | |
And I'm still in the dark about what a plate resistor actually 'does', apparantly it can have a 'too low' value. What consequences would this have? I've got my eyes on a small 125 V tranny, it would fit in my cd player, that's why. |
| no resistor values........ | pointy | Tubes / Valves | 19 | 18th December 2009 11:23 PM |
| Boostrap resistor values | Bing Yang | Solid State | 4 | 8th May 2008 04:44 PM |
| Resistor values | Valvomaniac | Tubes / Valves | 5 | 27th April 2007 04:50 AM |
| Resistor values | Stocker | Chip Amps | 3 | 4th May 2004 03:10 PM |
| Resistor values? | randytsuch | Chip Amps | 2 | 11th July 2003 01:08 AM |
| Page generated in 0.11561 seconds (78.94% PHP - 21.06% MySQL) with 10 queries |
