diyAudio Sponsor
Old 10th July 2010, 06:01 PM   #1
pmillett's Avatar
Default DC Filament supply boards
I've had a number of people ask me to make the DC filament supply boards I made for an earlier project available. I've finally gotten around to it...
Regulated DC filament supply
I made the PCB the same size/shape/mounting as the Tentlabs supply, so you can try this one (constant voltage) and replace it with the Tentlabs voltage-controlled-constant-current supply without any modifications to your amp.
Pete
When life hands you a jeffery, stroke the furry wall.
Old 10th July 2010, 08:59 PM   #2
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Hi Pete;
do you remember Dell & electrolytic capacitors issue?
The problem is, motherboard developers heated them up too much...
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 10th July 2010, 09:56 PM   #3
ChrisA is offline ChrisA  United States
I'm wanting to do something like this myself. One question. You say the CML drops some voltage. Why not have the regulator sample the voltage at the output terminals so as to compensate for the (load dependent) voltage drop. (Yes I know the heater load stays constant but some of use swap tubes around.) The cost and BOM remains unchanged.
Maybe there is a problem with this? Oscillation maybe?
In the past I've built power supplies for remote loads that had 50 or 150 feet of cable between the supply and load. I'd run one small gauge wire in the cable to sense the voltage at the load end of the cable so as to automatically account for voltage drop in the cable. Seems to me the inductor is exactly like a long power cable, only rolled up.
Old 10th July 2010, 10:07 PM   #4
pmillett's Avatar
Yup. If not oscillation, at least some AC response issues. One of my mantras is that if you want to use a regulated power supply in audio, make darn sure it does no harm. To me, that means the AC response has to be carefully controlled.
IMO, that's why shunt regulators tend to work well in audio. Less likely to get in the signal path (not that they do not or cannot...)
Taking the feedback after the CML could result in some AC response anomolies that might not sound so good...
Pete
Old 12th July 2010, 10:39 AM   #5
Gordy is offline Gordy  United Kingdom
ChrisA, sounds as if you may have been fortunate not to get oscillation with your long run. (Or may be just well designed ). I know that extending the negative leg (after / under the resistor) to the load can work well, but that does not normally apply to the upper / feedback arm.
Too right Pete. Experience suggests that the only thing that should go in the feedback loop of a three terminal regulator is a resistor, and that it should sit right next to the regulator.
Nice board Pete, thanks for posting that; I am sure it will be very useful to many of us.
Old 12th July 2010, 08:51 PM   #6
We were supping power, a handful of amps, to a thermoelectric cooling system. Bundled in the cable also was water tubing for the heat sink. If the load is not reactive and has a time constant of several seconds not much can happen. I think the "sense wire" was connected to a voltage divider that was in parallel to the load. You can do it. It's a pretty common technique.
Old 16th July 2010, 04:11 AM   #7
Hello Pete,
I just received a pair of your heater PCB’s in the mail. They are fine. Good job. Now the job is to see how low the noise can go on a 307A SET circuit.
DT
All just for fun!
Old 19th July 2010, 11:28 AM   #8
regal is offline regal  United States
Are you planning on making boards for the HF oscillator DHT heater design?
Old 19th July 2010, 07:44 PM   #9
pmillett's Avatar
I'm working on a new design for an ultrasonic filament supply... it will take a little time, but it looks promising.
Shooting for 2 x 2.5A at 125kHz, transformer isolated sine wave, in the same form factor as these boards.
Stay tuned!
Pete
Old 21st July 2010, 08:24 PM   #10
Pano is offline Pano  United States
Pano's Avatar
Stay tuned!
At 125Khz, I'll have to break out the old long wave radio to do so!
DC filament supply without electrolytic(s)? CarlyBoy Tubes / Valves 12 12th January 2010 01:33 PM
Rod Coleman filament supply circuit boards Hearinspace Tubes / Valves 33 7th February 2009 03:44 PM
When using a DC filament supply on a DHT... Saurav Tubes / Valves 31 18th September 2003 05:03 AM
DC Filament power supply oldstyle Tubes / Valves 26 2nd November 2002 01:26 PM
Page generated in 0.10791 seconds (80.35% PHP - 19.65% MySQL) with 10 queries
