tube/SS hybrid (low power)- need tube help
Old 26th June 2003, 09:17 PM   #1
trespasser_guy is offline trespasser_guy  United States
Default tube/SS hybrid (low power)- need tube help
Hi all. I attached the schem of a tube/SS amp I have been working on. It would be used for headphones... I just want some comments from tube-minded folks. Values:
C1- 1uF
C2- 4.7uF
P1- 100k
Q1, Q2- 2N5484
R1- 1M
R2- 330
R3- 200k
R4- 100
R5- 820
R6- 1k
R7- 1k
R8- 200k
R9- 1k
R10- 18k
R11- 1k
R12- 100
R13- 10
gain of opamp=10... biased into "class a", and all that stuff. I understand that... just wonder about the tube section. Opamps will run on either +/-12V or +/-15V... lost my good tranny so I may have to settle for 12V.
The tube will be run at +/-42V, probably. Does everything look ok?
How do you think it would sound? I haven't really heard many good things about tube/SS hybrids, but some peopl use them... so I thought I'd check them out. Thanks
Old 26th June 2003, 09:26 PM   #2
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
But what's the purpose of the valve? It's clearly redundant in this circuit. It would probably have some justification if you had a valve amplification stage followed by a buffer to match the load, but as shown it only adds noise and distortion. This is not what valves are meant to do.
Old 26th June 2003, 09:35 PM   #3
On Hiatus
SY's Avatar
And why use a bipolar supply if both the tube input and output are capacitively coupled? If you wanted to use a much simpler single-ened supply, the redundant R1 can be snipped out.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 26th June 2003, 09:58 PM   #4
The tube is just supposed to put in its 'tube sound' and not do much else- add a tiny amount of gain. How bad of distortion? Hmm...
Old 26th June 2003, 10:04 PM   #5
On Hiatus
SY's Avatar
I doubt that. It's a cathode follower.
Old 26th June 2003, 10:56 PM   #6
zobsky is offline zobsky  India
zobsky's Avatar
i'm interested in this too, kinda ....
suppposed i wanted to use a tube pre-amp with a solid state power amp i have to inject some "tube flava", would i not use something like trespasser_guy, ..except maybe tap off with a bypass cap at the anode, as opposed to the cathode?
i already did this when testing the pre-amp section of a simple 6bq5 triode strapped amp i built last week. ..but is this the correct way to do this
questions from a newbie
Old 26th June 2003, 11:21 PM   #7
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
One word: forget.
Frank
Old 27th June 2003, 12:02 AM   #8
So, more or less, there really is no way to implement it and achieve a suitable result?
Old 27th June 2003, 12:07 AM   #9
zobsky's Avatar
well for headphones only / preamp use, there are several excellent tube-only designs. headwize has some good info
Old 27th June 2003, 01:01 AM   #10
Yes... but they all cost a fortune... if done right. And, this way, I would be able to build something I know how to build (the SS part) so in the event that the tube thing didn't work out, I still had a good SS headphone amp. Plus, I'd get to use up my OPA637s and BUFs. I would love an all tube, and was about to order the parts a few days ago... but talked myself out of it because I have never done it before, and the amount of money I'd sink in it is a lot to lose...
tube/SS hybrid (low power)- need tube helpHide this!Advertise here!
Hybrid Amp, Tube+MOS FET SE ja2dhc Tubes / Valves 2 5th July 2008 03:12 PM
hybrid power supply: diode bridge into diode tube engels Tubes / Valves 8 24th September 2007 10:18 AM
Tube Hybrid Amp. neg2led Tubes / Valves 11 3rd September 2006 01:38 PM
Hybrid amp -> tube for VAS stage rtarbell Tubes / Valves 3 26th November 2005 10:13 PM
Copyright ©1999-2017 diyAudio
