diyAudio Sponsor
Old 8th July 2010, 08:46 AM   #1
Default Advice on 6P3S p-p amp schematic, feedback problem?
Hey guys, here's a really rough schem of what I'm thinking of doing for an AB2 p-p 6P3S amp.
Its a triode input stage (6N1P) into a an LTP consisting of a 12AX7, followed by 12AU7s as CFs providing drive current for the AB2 output stage.
I'm also considering MOSFET's instead of the 12AU7's.
The values in the schem are rough values that work in simulation, but nothing is set in stone at this stage.
One problem I've found is providing feedback to the input stage or reducing its gain to get the sensitivity right.
I considered GNFB maybe by grounding the 4 Ohm tap of the OPT and using the 16Ohm tap for cathode feedback to the input stage, but enclosing that number of stages I'm worried about stability.
Any suggestion relating to any part of the schem, and particularly the problem of getting the input sensitivity right, are welcome.
Old 8th July 2010, 03:34 PM   #2
whoops. those 12au7 CFs should be 6N1P's with cathode resistors, not CCS.
Feedback problem with Guitar amp .... Minion Instruments and Amps 4 9th June 2009 10:13 PM
6P3S SE amp requesting jkraxi Tubes / Valves 1 19th December 2007 11:43 PM
Found Meixing Amp schematic, sorta, would like some feedback pjpoes Tubes / Valves 3 4th March 2007 04:22 PM
advice on an EL84 Push pull Amp schematic colin.hepburn2 Tubes / Valves 6 2nd June 2006 04:02 AM
Automatic Gain Control - 50W amp needs a good feedback schematic! styoshi Solid State 3 23rd April 2004 09:11 PM
Page generated in 0.07242 seconds (65.73% PHP - 34.27% MySQL) with 11 queries
