| diyAudio Sponsor | ||
I've been characterizing some transformers that came from old console ampliers, reportedly Magnavox. One pair is SE, the other P-P. The size tends to indicate thay were used with 6BQ5 or similar tube types. I characterize transformers by driving the primary with a signal from a sine wave power source at 50V RMS, 300Hz. The 50V amplitude gives me a good signal at the transformer output and enough voltage to properly excite the core so that I can get readings for primary inductance under large-signal conditions. I also monitor the input current using a Yokogawa WD210 power analyzer, so that I can calculate large-signal primary inductance.
Anyway, to the chase. The SE transformers measured 1.24V out for 50V input. This is a turns ratio of 40.3 to one. This is squared for the impedance transformation. Assuming 8 ohm load, this is a 13k primary impedance, which seems rather high, unless the speaker load is really 4 ohms. Primary inductance was ~30H, which is respectable. The P-P transformers measured 1.15V out for 50V in. This is a turns ratio of 43.5:1, or a primary impedance of 15k for an 8 ohm load - again, a 4 ohm load sounds more plausible. Primary inductance was 60H, again respectable. Anyway, can anyone with experience parting these consoles out tell me wheter you have encountered 4 ohm speakers? |
#2 |
You might want to confirm that sec out voltage down at 40 Hz too. Most commercial core is all done by 250 Hz for passing power and above that you are getting into antenna event coupling only. This is especially true of the beloved 26 gauge M19, called audio core, that most audio transformer manufacturers used.
I think most of those ancient alnico speakers were actually 16 ohm, unless they were a weird variant, like 12 ohm. Magnavox could have anything they wanted after all. Bud
"You and I and every other thing are a dependent arising, empty of any inherent reality" Tsong Ko Pa |
#3 |
I just went back in the lab and drove one of the SE transformers again at 50V RMS, varying the frequency from 60Hz upward. I also placed a 10 ohm load at the transformer output. Output voltage under these conditions was pretty constant with frequency (a little down at 60Hz, though) at 1.14V out for 50V in. This is still a rather high turns ratio, and tends to indicate a 4 ohm load rather than 8 ohms. I have some organ transformers that when subjected to this test, indicate that they were intended for 16 ohm speakers.
#4 |
dunno about the maggies, but I have run into locally built Philips units with 2 ohm, 12 inch speakers!!!! Majority here were nominal 16 actually 15 ohm. Cheers!
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012 |
#5 |
Those are 4 ohm transformers IMHO. I have had around twenty different magnavox consoles pass through my hands. Almost all of their outputs were 4 ohms as far as i remember. Post any numbers that are on the trans. and i can check the sams for maggies and probably give you all the specs. I seem to remember the some of the pp trans had 3.2 ohm secondaries
#7 |
Transformers were sorta cruddy, but I managed to get some numbers off of them. The P-P transformer is C320085-2, and the SE is 320083-1
#8 |
Yet another possibility can't be ignored. An awful lot of consumer stuff was made with 3.2 Ω cone drivers.
Eli D. |
#9 |
I may just say to heck with the turns ratios and find alternate uses for the transformers, such as a plate choke in the case of the SE transformers (like maybe on top of the husky triode half of a 6GF7), or in the case of the P-P transformers, use the primaries in an autotransformer phase splitter.
#10 | |
Most wax coated transformers from old radios, TV's and HiFi sets that have been in south Florida for 50+ years look like that, but they usually work. I know the SE amp was working when I parted it out. I had it at work for a while connected to a PC and a set of plastic speakers. It sounded pretty good but the safety people really didn't like it and it had to go.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
| Magnavox Console Amp Chassis | wrenchone | Tubes / Valves | 10 | 23rd June 2010 03:06 AM |
| Magnavox console amp, SE EL84, $50 | pjanda1 | Swap Meet | 5 | 27th January 2008 09:02 PM |
| Newbie needs Magnavox console troubleshooting tips | robertleo | Tubes / Valves | 10 | 20th December 2007 01:55 PM |
| Salvage Magnavox Console | bcrescen | Multi-Way | 1 | 17th March 2007 01:12 PM |
| Speaker impedances | Vivek | Everything Else | 11 | 30th July 2001 08:07 PM |
| Page generated in 0.10463 seconds (80.90% PHP - 19.10% MySQL) with 11 queries |
