diyAudio Sponsor
Old 2nd July 2010, 08:16 PM   #1
ampped is offline ampped  Canada
Default first tube amp
im looking too build a tube amp to power two small 5 inch speakers ,
and play records
i have little circuit experience i cant read plans , well sort of
any one know of any decent kits ,
diagram / part list and instructions
i want too spend under 100$ if possible
thanks
dave
Old 2nd July 2010, 09:03 PM   #2
Your $100 budget is too low. The magnetics alone cost more. The attached "El Cheapo" design should meet your needs. You supply case work of your liking. Jim McShane will sell you the requisite parts and tubes.
If the project whets your appetite, I'll provide references for power and O/P "iron", along with a thread (very lengthy) regarding its history.
Eli D.
Old 2nd July 2010, 09:21 PM   #3
Soonerorlater's Avatar
and play records
Do you mean cd's , tapes, Vinyl?
Brgds Bill
Old 2nd July 2010, 10:31 PM   #4
Hi, Dave
With your budget you only spoil the first impression and do not want more to return to the tube sound.
If it were not for the budget, then I would recommend my Level Five Amp
Old 2nd July 2010, 10:38 PM   #5
aardvarkash10's Avatar
just for another option, pick up an old console unit - that gives you donor iron and hopefully tubes. Cost will be anything from free to a quarter-ton depending on where you find one.
Then take a look at the range including RH84, El-Cheapo, the basic version of Baby Huey and Simple PP (or SE).
The design WILL be dictated by your donor, but at least you are over the bit of purchasing your major parts.
Beware - once you start, you are hooked.
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012
Old 3rd July 2010, 02:24 AM   #6
Brgds Bill
records mostly
Old 3rd July 2010, 02:31 AM   #7
ill be playing records mostly
now i looked at the el-cheapo , and that looks perfect .
were can i find out how too read one and what all the b- and b+ go ?
ltp cathodes is
and the arrow/triangle
Old 3rd July 2010, 02:36 AM   #8
i'm interested in learning more about el-cheapo
Old 3rd July 2010, 03:37 AM   #9
The LENGTHY saga of "El Cheapo" is here.
A complete set of power magnetics can be obtained from Allied Electronics. Stock # 967-2343 is the Triad N-77U primary B+ trafo. Stock # 967-8019 is a Triad VPS24-1800 2X "12" VAC filament trafo, which provides heater power to the 12AL5 and the O/P tubes, along with B+ boost. Stock # 967-1004 is a Triad C-24X B+ filter choke. Stock # 227-0034 is an Allied 6K27VF trafo that energizes the B- rail and powers the 12AT7 heaters.
As a cost containment measure, I suggest the $37.01 Edcor model GXPP15-8-8K as the O/P trafo. Used with triode wired "finals", as shown in the previously provided schematic, will yield a decent "6" WPC. Better (as in more expensive) O/P trafos will permit ultra-linear mode "finals", which will yield "12" WPC.
BTW, how deep do the 5 inch speakers go?
Eli D.
Old 3rd July 2010, 04:01 AM   #10
tinitus is offline tinitus  Europe
I suppose that should have been 12AT7
Would it be ok to use 6V6 ?
6n6p tube as output tube for small guitar amp moonbird Tubes / Valves 28 7th September 2011 04:28 AM
Simple Tube Mono Block Tube Amp Schematic jleaman Tubes / Valves 16 24th November 2009 08:42 PM
FA: Eico HF-85 Tube Preamp & HFT-90 Tube Tuner joe-electro Swap Meet 0 31st May 2009 04:14 PM
FS tube tuner, Active filter kit, tube amp, amp3 Josephjcole Swap Meet 9 20th July 2007 04:05 PM
SS or tube voltage amplifying stages in an amp with tube output? ray_moth Tubes / Valves 14 4th July 2007 03:09 AM
Page generated in 0.12626 seconds (75.74% PHP - 24.26% MySQL) with 11 queries
