diyAudio Sponsor
Old 2nd July 2010, 01:38 PM   #1
tinitus is offline tinitus  Europe
Default PushPull vs ParalelSE
Any reason why we never see any Paralel SE with say 4x EL84 in paralel ?
Old 2nd July 2010, 02:01 PM   #2
DF96 is offline DF96  England
High power SE needs big expensive transformers. If you are doing something big and expensive, you might as well use a big expensive valve too.
If you want to use a pair or quad of EL84, better to use P-P and have a cheaper transformer and largely cancel even-order distortion. Also have less audio going through the PSU.
Old 2nd July 2010, 02:43 PM   #3
EL84 Quad SE
None of us are leaving this world alive. Enjoy it responsibly as you may.
Old 2nd July 2010, 03:37 PM   #4
Ok
seems Lundahl LL1627 cost the same whether its PP or PSE version, 190EUR ea
http://www.lundahl.se/pdfs/datash/1620_3_7_9202.pdf
Old 2nd July 2010, 03:55 PM   #5
But the PP version has much higher primary inductance so handles low frequencies better, and can handle much higher power. So for a given performance, a PP transformer is much smaller and cheaper than an SE transformer.
Old 2nd July 2010, 04:13 PM   #6
kevinkr's Avatar
Push pull operation of a pair of tubes may give you as much as 4X the power of a single tube in SE, whereas PSE will give you 2X the power.
The objection some people have to PSE is that it is alleged to loose something sonically (imaging, timbre, detail) as compared to a single tube implementation. IMLE with some high end 300B amps (very expensive, but to remain nameless) this did in fact seem to be the case.
www.kta-hifi.net
Old 2nd July 2010, 04:20 PM   #7
Bigun is offline Bigun  Canada
Bigun's Avatar
I'm not surprised PSE sounds different from SE given that you effectively have a different tube in there - with two tubes in parallel the average transfer curve isn't the same as either tube, total inter-electrode capacitance will be higher etc.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 2nd July 2010, 04:25 PM   #8
Yvesm is offline Yvesm  France
Yvesm's Avatar
Originally Posted by Andrewbee View Post
OMG
1st of April issue ?
Old 2nd July 2010, 04:29 PM   #9
Yvesm's Avatar
Originally Posted by tinitus View Post
Ok
Sure . . . but look at "Max Power" . . .
Old 2nd July 2010, 04:43 PM   #10
hey-Hey!!!,
For Class A operation, two tubes PP deliver the same power as two PSE. Now with PP one can go AB or even B and step power up considerably( though I am not at all convinced it is a good idea). PPP or 4PSE ( each with 4 finals ) does the same thing with a change to the power multiplier over single-final SE.
cheers,
Douglas
the Tnuctipun will return
300B pushpull- A new schematic waltube Tubes / Valves 6 7th May 2009 12:41 AM
EL34 Pushpull imbalance fpelleti Tubes / Valves 10 23rd October 2008 05:04 PM
50CA10 pushpull amp soundbrigade Tubes / Valves 2 4th November 2007 06:58 AM
sensitivity rating of pushpull sub fergs1 Subwoofers 8 19th November 2006 11:42 AM
Page generated in 0.09797 seconds (75.39% PHP - 24.61% MySQL) with 10 queries
