diyAudio Sponsor
Old 2nd July 2010, 12:22 PM   #1
rsumperl's Avatar
Default Painting transformer end bells
Greetings everyone,
I just had a pair of end bells blasted to get all the old paint off. The question is should I paint the inside?
Thanks,
Ray
Old 2nd July 2010, 12:48 PM   #2
tubelab.com's Avatar
If you live anywhere where the humidity is high, paint them, otherwise they will rust. Bare steel lasts about 5 minutes in south Florida.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 2nd July 2010, 01:01 PM   #3
rsumperl's Avatar
Thanks, my intention was to put the oven on low when the wife is at work and bake after painting. And yes, I had lived in Melbourne for quite a few years and unless it was painted, it rusted!
How's the sweep tube experimentation coming?
Old 2nd July 2010, 01:16 PM   #4
I have very little time now since I tend to be at work for most of my awake hours right now. I should get at least 2 days out of the 3 day weekend coming up, so there might be some glowing tube time. I finally got to stick a pair of the 35LR6's that I got at the Dayton hamfest into the red board and crank 250 watts out of a single pair of tubes.
I recently blasted and painted the end bells from some old HP transformers for reuse on some open frame OPT's. I primed them inside and out with flat black RustOleum spray paint, then sprayed the outside with several thin coats of Krylon gloss black. I just left them outside in the sun to dry. They came out very nice.
Old 2nd July 2010, 01:19 PM   #5
rsumperl's Avatar
Do you suggest I prime first? I did buy the rustoleum paint, but didn't give priming a second thought.
Old 2nd July 2010, 04:23 PM   #6
In my case I had several cans of paint already from other projects. The Krylon specifically stated to "prime bare metal" on the label, and the Rustoleum said that it could be used on bare and even rusty metal. The rustoleum wasn't shiny, so I used it as a primer, and as the top coat for the laminations.
Old 2nd July 2010, 06:25 PM   #7
Miles Prower's Avatar
Definitely use primer.
It is also a good idea to prepare the surface by giving it a good scrubbing with plenty of soap and hot water to de-grease it. Dry well, and then wash it down with acetone. This helps remove any residual grease, and helps remove moisture. Once this is done, don't touch the surface, and prime with the Rustoleum red iron oxide primer (reddish-brown in color). Let dry 24 hours, and don't touch. Then paint with the color of your choice (I use Rustoleum paint for this as well).
This is how I painted the steel chassis's of a couple of projects I did, and haven't had the paint bubble up and peel yet.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 2nd July 2010, 06:35 PM   #8
I have used that primer as well on a really rusty trailer we use at work and that paint has stuck to it for five years now with no signs of bubbling or flaking.
- Nic
Old 2nd July 2010, 06:53 PM   #9
rsumperl's Avatar
What is the feeling about air dry vs low temp oven dry. My thought since the wife will be at work is to do a low temp oven dry.
Thanks,
Ray
Old 2nd July 2010, 06:54 PM   #10
Yes, clean is important. I used a Scotchbrite pad with water. After dry, wipe down with a lint free cloth and a solvent. I use lacquer thinner or mineral spirits, and work outdoors. Acetone has a lower flash point than gasoline. I saw two incidents of spontaneous trash can fires due to acetone before it was banned from the factory and replaced with some Freon derivative, which has also been banned.
crown dc300a transformer end cap krmaudio Solid State 0 4th December 2008 06:04 PM
EI-75 End Bells dsavitsk Tubes / Valves 2 18th April 2008 11:28 AM
Transformer End Bells rlaury Tubes / Valves 5 17th January 2006 08:15 PM
Ring any bells? Lisandro_P Everything Else 0 24th February 2003 03:41 AM
Page generated in 0.11212 seconds (83.46% PHP - 16.54% MySQL) with 11 queries
