diyAudio Sponsor
Old 1st July 2010, 10:21 PM   #1
Question Strange Noise From Amp
Hi guys,
I have basic understanding of amplifier operation, and I'm trying to gain some further knowlege. I have a problem with an amp I acquired second hand about six months ago:
Starting a few days ago when I first turn it on it makes a motorboating type noise until it warms up, then it's fine. The amp is a Wavac MD-300B I can not seem to obtain a schematic of its circuit. Right now I only have extra input tubes to roll, and that doesn't seem to be the problem. Anyone have any ideas? How about schematics for this amp? They seem to be sequestered. Thanks for the help.
Best,
Steve
Old 2nd July 2010, 06:29 AM   #2
mjf is offline mjf  Austria
hello.
have you an idea how old this amp is?
.......if it is older than 20 years or so you can begin with changing old bypass electroytics.there are often some small elcos inside like 4,7uf.........10uf....... parallel to resistors.perhaps any bad elco is the reason for motorboating.
greetings
Old 2nd July 2010, 02:23 PM   #3
Thanks for the response. I don't know how old it is. I can't even seem to find out how long they've been making it for.
Replace bypass caps: check.
Could you explain why the motorboating subsides after warm up? Thanks again.
Steve
Old 2nd July 2010, 03:07 PM   #4
DF96 is offline DF96  England
Two reasons why LF oscillation can sometimes reduce when warmed up:
1. The whole feedback loop has such a peculiar phase response that reducing gain causes oscillation. This sounds counter-intuitive but the maths of loop stability says it is possible. It is not often seen though.
2. The unwanted feedback is via the HT supply but under normal conditions there is some degree of cancellation. During warm-up some stages come up faster than others so the balance is temporarily disturbed.
The second one is more likely, and could be caused by a capacitor changing value due to age. Without a circuit diagram it is difficult to say more.
Old 2nd July 2010, 08:29 PM   #5
Follow up: This problem turns out to be intermittent. Today when I fired the amp up, it didn't let out any unpleasant burps at all. Would this point to caps that are teetering on the edge of giving out? Could an iffy tube make this type of noise? I've heard crackly tubes,and wavery sounding tubes, etc., but not burping.
Old 2nd July 2010, 09:26 PM   #6
Stick some photos on of the guts. It shouldnt be too much to work out
Cheers Matt.
Musical Fidelity P270 - strange power off noise Nrik Solid State 13 16th March 2012 11:18 PM
Strange noise...? Skorpio Solid State 16 6th August 2007 06:21 AM
strange noise from right channel keyser Everything Else 15 2nd May 2005 10:14 PM
Strange noise form lm3875 velikan Chip Amps 2 1st March 2005 04:45 PM
About strange noise from my amp! Otherwise Solid State 6 11th September 2003 12:12 PM
Page generated in 0.09007 seconds (71.46% PHP - 28.54% MySQL) with 10 queries
