| diyAudio Sponsor | ||
Hi again...
Here are some squiggles I drew: ![]() I was thinking that if a CCS was a good thing as the load for a cathode follower, then a choke should be too. I know the choke pictured above doesn't have much inductance (22H). Is that still a problem considering the very low output Z of a CF? -- I know a choke isn't as good a load as a CCS, and will have bandwidth limitations a CCS might not, but my question is meant more for my learning/understanding than for building the best possible circuit. |
#2 | ||
#3 |
R.I.P.
Your theory is correct, a choke can replace a CCS - but only under certain conditions. But neither circuit is much good as drawn, as both will very easily overload with any sort of signal level. The cathode of a CF should sit well above gnd, ideally around half the B+ rail to allow maximum voltage swing before any clipping, up or down. This means the grid of the CF needs to be elevated to the same voltage, and the cathode impedance adjusted to suit. Note that a choke will not work with near half the B+ across it...something will smoke.
Regards, Allen |
#5 | |
In case of CCS load it should sit at (B+ - Vs)/2 where Vs is a saturation voltage on the max current. In case of resistor load it should sit at (B+ - Vs)*3/4
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#6 | |
![]() I'm glad somebody is thinking outside of the sand box. Last edited by Jeb-D.; 30th June 2010 at 11:39 PM. |
#7 | |
R.I.P.
2/ The schema the OP drew shows a choke in a zero biased triode CF. Assuming the choke has enough DCR to act as a suitable cathode bias R, it will still have VERY limited output swing, and make massive 2nd harmonic distortion before clipping. Regards, Allen |
#8 | |
Triode CF is not ZERO biased. It is biased up to the current needed for a maximum of a negative voltage swing on a given output load. Second harmonic distortions will be way below what you may get from an identical common cathode stage with choke loaded anode. Edit: you may search for Altec 1570 schemo.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! Last edited by Wavebourn; 30th June 2010 at 11:58 PM. |
#9 |
Thank you. I'm not so old to forget physics' basics I learned 40 years ago.
#10 | ||
A little controversy!
...The inductance of the choke, which will resist changes in current, creating an AC load that causes a signal voltage swing across the resistance... I think. Being a buffer with a grid bias of +8V, wouldn't a stage like this CF be used to match a previous high-Z gain stage (amplifying a 500mV signal to let's say 2Vrms) to a subsequent stage requiring a lower Z? So an 8V grid bias would be plenty in that application, right? Quote:
| Cathode follower question | woody | Tubes / Valves | 6 | 10th October 2005 02:10 AM |
| cathode follower | vlljpior | Tubes / Valves | 6 | 22nd March 2005 07:50 PM |
| Question about direct coupling a anode follower into a cathode follower. | G | Tubes / Valves | 45 | 29th July 2004 06:47 PM |
| cathode follower | ackcheng | Tubes / Valves | 2 | 6th July 2004 03:12 PM |
| Page generated in 0.11056 seconds (82.73% PHP - 17.27% MySQL) with 10 queries |
