I'm bringing a pair of neglected Dynaco MkIIIs back to life, and am considering changing to 6AR6WA/6098 output tubes. Is this a viable option?
I'm retaining all of the original iron, and installing Triode Electronics input boards. I'll also upgrade the PSU caps, and may consider switching to a stiffer choke.
My incentive for changing the output tubes is primarily cost, with quality an additional factor. I have several matched quads of NOS Tung-Sol JAN 6098s. I don't think I can find a current production 6550 to equal the original Mullard/GEC pentodes, and the price of NOS 6550s is ridiculous.
Is this a good avenue to travel? If not, are there Russian milsurp tubes which would be a better choice?
Thanks in advance for your opinions and/or experiences.
I thought about 6CA7s, but unfortunately, I only have three. Bird in the hand, and all that...
BTW, here's a link to the entry on another forum which got me thinking about the 6098 option: Tubes Asylum - 6AR6/Triode Input Board/MIT-RTX/max build - Chris Spafford, February 11, 2003 at 17:28:35
I don't know if the poster's obvious enthusiasm stayed so high over the long run, but he sounded pretty pleased with the initial results.
screen voltage max is 300Vs with 3.2Ws dissipation and with a plate dissipation of 19Ws, it's certainly a different beast than the 6550/KT88.
However, I have a friend who ran 6AR6s in his Mark IIIs - coincidentally, he used the Triode Electronics input board too. If I remember correctly, he ran them with the stock B+ voltage and dialed back the bias. The 6AR6s _were_ being heavily abused and would last six months before he would have to replace 'em. Since he had about 100 of the little buggers, he really didn't care!
In a trade, I ended up with these Dynaco Mark IIIs and rebuilt them from the ground up. I ended up running SED 6550s and also played with the top cap EL38 (required a bias supply change).
George (Tubelab) would not be impressed at all.
I have a box full of used Tung Sol 6AR6's. I "tested" a few and was not too impressed. They bases are rewired to solve the problem inherent in 6L6GC, EL34, and KT88 types where the plate (pin 3) is adjacent to the heater (pin 2). I have seen several guitar amps arc over at the socket pins when driven to clipping with an incorrect load. This means that you can crank up the plate voltage with 6AR6's, but the dissipation limits remain.
The Bendix 6384 version is a different animal that can be cranked hard. It is unfortunately expensive and hard to find.
While far from inexpensive, "reissue" Gold Lion KT88s made by New Sensor at Saratov, Russia are good tubes. FWIW, feedback from the field finds the "reissue" GLs as being sonicly EXCELLENT.
IMO, the best NOS option is employing TT21s and adapters.
If you want cheap, ask yourself if you feel lucky. I stuck a set of Chinese 6L6 into my Mark III for a short while. Surprisingly, no fireworks. I think I paid about $1 each for a dozen of these things. Not that I'd recommend you try the same - I'd hate to think what could happen if a dodgy tube went pyrotechnic and tried to take out a transformer with it.
- Tubes / Valves
- Modify Dynaco MKIII to use 6AR6s ?
