| diyAudio Sponsor | ||
Hey
I am working to shrink a tube amp, and for this work, I lack a few rules of thumb from a few experienced builders. The hv psu built by CLC with the final C placed on the amplifier chassis. The actual power xmr, rectifier, the first cap and choke is built into a separate cabinet standing on the floor. I am missing the following: 1: Minimum distance between ECC8x tubes. Problem = Heat 2: Minimum distance between 6SN7 octal tubes and similar tubes. Problem = Heat 3: The minimum distance between 6L6, 807 and similar power tubes. Problem = Heat 4: Distance between tube and OPT. Problem = magnetic field 5: Distance between the two OPTs. Problem = magnetic field And Yes i know to take care not to heat op the caps. Benny |
#3 |
hey - time honoured and tightly packed.
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012 |
| Heat Shrink tubing | jim5763 | Swap Meet | 0 | 20th February 2010 03:03 AM |
| How do you shrink heatshrink? | Atilla | Everything Else | 26 | 23rd June 2009 01:46 PM |
| Custom labeled heat shrink order | Mach_Y | Car Audio | 1 | 9th November 2006 10:09 PM |
| How could I shrink some 2''PVC pipe | Guss | Multi-Way | 23 | 21st February 2004 07:02 PM |
| Page generated in 0.08003 seconds (73.00% PHP - 27.00% MySQL) with 11 queries |
