| diyAudio Sponsor | ||
simple using cathode follower on 6SN7 SRPP
easy to try - unbelivable result
visit my best audio idea http://www.esafono.it/DACTONE.htm |
#3 |
Hi Stee;
What do you smoke this time?
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#4 |
The secret is the plates of the lower tubes are tied to ground thru 510 Ohm resistors. Must be a plate follower.
Craig |
#5 |
They seem to be coming in droves this weekend.
Stee, what are you trying to accomplish here? The design looks fundamentally flawed.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#6 |
He's just ripping off other people's schematics and mangling them. At least he left out the 4.7K resistor in series with the speaker this time ...
mod verb, transitive /mod/ to state that one is utterly clueless about the operation of device to be "modded" and into "fixing" things that are not broken; "My new amplifier sounds great so I want to mod it." |
#7 |
I think this is the first time I've laughed at a circuit diagram
#8 | |
R.I.P.
If you want just x1 gain CF outputs, it can be done 1/ far better and 2/ far simplier. Regards, Allen |
#9 |
Hey Stee,
Great, you´re capable of using both rubber- and pencil- as well as the text-tool in MSPaint. So now you´ve got a digital drawing of an overcomplicated, easy distorting CF capable of a some hundred volts positive swing and about three volt negative swing. Personally I like to drink lots of Tuscan wine to my pasta. Do you?
Brgds Lars Last edited by revintage; 28th June 2010 at 03:19 PM. |
#10 | |
| The secret of building a good 2-way | Defo | Multi-Way | 190 | 10th May 2012 01:58 PM |
| The secret janey | peranders | The Lounge | 1 | 30th January 2006 09:09 AM |
| What's the secret? | lumanauw | Pass Labs | 23 | 31st March 2005 04:11 AM |
| the secret was in the cookie jarr | jazz | Everything Else | 5 | 23rd December 2004 07:21 PM |
| Jfet preamp secret | leiade | Solid State | 14 | 16th September 2002 01:26 AM |
| Page generated in 0.10313 seconds (78.19% PHP - 21.81% MySQL) with 11 queries |
