diyAudio Sponsor
Old 27th June 2010, 05:02 PM   #1
makokoy is offline makokoy  United States
Default HELP to ID push pull/Single Ende
I purchased a vintage tube amp Columbia yesterday that need repair I need help to ID if this schematic push pull/Single Ended & power amp/integrated
thank you
Old 27th June 2010, 07:28 PM   #2
Tube amps can kill. The high voltages required are deadly; start slowly and read the stickies first, that way you will have plenty of time to decide how to proceed with your amp.
Old 27th June 2010, 08:00 PM   #3
tubelab.com's Avatar
To answer the questions, it is a stereo push pull power amplifier that does not have its own volume control. It was intended for use as part of a larger system, probably a console stereo. The volume and tone controls were part of the matching tuner. It can be used stand alone with the addition of a volume control. It is probably 15 to 30 watts per channel.
This unit used a selenium rectifier in the bias circuit which can release a toxic stink when they fail, which is likely. The capacitors probably need to be replaced too. If this all sounds unknown to you, get the assistance of someone who understands. Just plugging it in will probably blow up some parts.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 30th June 2010, 07:58 PM   #4
thank very much tubelab and mctavish
the amp is dead now one channel was working when I bought it.
Single-ended OR push-pull? kacernator Tubes / Valves 48 31st March 2008 02:50 PM
modify parallel push-pull EL84 to single push-pull chungtat Tubes / Valves 12 3rd November 2005 11:25 PM
Parallel single ended or push-pull? Jeffy74 Tubes / Valves 6 12th February 2004 06:04 AM
Double push-pull versus single push-pull jraraujo Tubes / Valves 19 19th October 2002 12:23 AM
Page generated in 0.09354 seconds (67.12% PHP - 32.88% MySQL) with 11 queries
