| diyAudio Sponsor | ||
I have little experience with tube amps (built 1 spud) and have 8 Russian 6n6p tubes. Im building a preamp and would like to use the tubes as a buffer for the output to lower the impedance after the pot.
Is there a simple schematic someone has for this using a cathode buffer with 1 tube? Im in the USA so I was thinking of just getting 2 6.3vac transformers and running 1 to the wall to step down to 6.3, then connect the other one to step it back to 120vac and use a full bridge rec to convert to 170vdc. Can i just copy Lamps version that he uses for his dac's? |
#2 |
mod verb, transitive /mod/ to state that one is utterly clueless about the operation of device to be "modded" and into "fixing" things that are not broken; "My new amplifier sounds great so I want to mod it." |
#3 | |
You mean this? Preamplifier_with_HEAD You can adapt it, but the performance may be mediocre. |
#4 |
While undoubtedly sound, SY's design is anything but simple and could be a trap for a builder with little experience.
FWIW, I suggest 10M45S constant current sink loaded cathode followers and a bipolar PSU. That sort of arrangement places only 1 cap., at the unit's O/P, in the signal path. A 4.7 μF metalized polypropylene part bypassed by a 470 nF. 716P series Orange Drop does that job well, without spending a lot. A $25 AnTek model AN-05T160 power trafo looks like a reasonable fit for the job. To get a bipolar supply, each rail would be 1/2 wave rectified, but making the 1st filter caps. big deals with that matter. A single filter choke can be shared between the 2 rails, in the grounded leg. A pair of 600 PIV Schottky diodes for rectification are inexpensive enough and yield "noiseless" operation.
Eli D. |
#5 |
Oh man Eli is following me again. Um with a BP supply i halve my voltage so supply caps would be alot cheaper. Any schematics or something to go on? Since im a beginer i cant make anything from scratch. I just wanted to get some tube sound to my Tamp and 3886 amp i built up.
Heres what i was going to adapt. http://www.lampizator.eu/lampizator/...X/IMG_5144.jpg its got 2 caps in the audio path, but the first can be small so i can get something nice. The output cap might set me back alittle if i go full metal film. |
#6 |
Nightanole, But that's not a cathode follower, it's an anode follower. However, with the lowish plate impedance of the 6n6, you may not need a cathode follower. I use a 6n6 preamp and take the output from the plate, no problem.
#7 |
It's not even an anode follower, it's a common cathode amplifier. The design is... questionable.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#8 |
see this, but it has to change for 6n6p, that and a very good blog 10000 circuits...
http://circuitoseletronics.blogspot....-follower.html Moderator Warning Note:
sorry if wrong, my English is google translator |
#9 |
#10 | |
Try again!
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
| help !! 5687 cathode follower as cd buffer | costa23 | Digital Source | 0 | 25th March 2010 01:06 AM |
| 6N6P cascode + 6AS7 Cathode follower | croccodillo | Tubes / Valves | 12 | 15th September 2007 09:33 AM |
| Cathode Follower Buffer Input Impedance | xcortes | Tubes / Valves | 5 | 1st December 2005 05:10 PM |
| Basic Cathode Follower buffer | dsavitsk | Tubes / Valves | 11 | 26th June 2005 04:25 PM |
| Question about direct coupling a anode follower into a cathode follower. | G | Tubes / Valves | 45 | 29th July 2004 06:47 PM |
| Page generated in 0.11412 seconds (82.42% PHP - 17.58% MySQL) with 11 queries |
