| diyAudio Sponsor | ||
Hi everyone!
I'm new here and I think the forum is really good. I made two guitar amps, 1 and 5 W. Now I made a HI-end amplifier from a few watts. And now that I need you. Which amplifier? 6c33 or 300B or simply with EL84 (with them I have the experience). Amplifier may not be top. (We say in Croatia: "The first kittens are thrown into the water" <= this is a joke.) Maybe something with ECC82 + EL84 or similar? The forum is a lot of schemes. Let's extract that to me. Thank you very much. Dean |
#2 |
This depends on what you are trying to do. I assume you want a slow journey up the power scale, so your 1 and 5 W amplifiers could be a prelude to an 8 W unit using a pair of 6BQ5 tubes.
There are so many circuits to build it's hard to advise you. It will depend on what parts you have available. I prefer solid state and am in the process of building an amplifier with the LM4780. This unit, barely 2 cm square, can deliver 120 W of audio. I don't plan on making a unit that powerful. I recently built one with about 25 W, also solid state. My philosophy is to build amplifiers without distortion. I don't care for the sound of amplifier distortion, even with guitars. I prefer the clean smooth sound of players like Charlie Christian and Les Paul and Barney Kessel. Definitely jazz oriented, not rock. |
#3 |
Hi!
Tube amp 1 and 5 W are the guitar and that's another story. I would like to make a tube amp to 10 W for cd player and radio for the home. Parts are no problem, but as this is an amateur work, I do not want to invest a lot of money. Dean. |
#4 |
So a push pull tube amplifier for 10W? You can use 6BQ5's as an example. You will need an output transformer and a power supply and a driver stage. If you want volume, bass, and treble controls you will need a stage for that. The driver can be a 12AU7 and the tone amplifier a 12AX7.
Figure maybe 300 Volts for the output stage. Look in the tube manual to find the proper bias, then create that either with a bias supply or cathode resistor. Of course you will need to do all this twice (except the power supply) for stereo. Rather than trying to design every component value, you can take a short cut by searching for existing amplifiers using similar tubes and copy the schematic diagrams with minor changes to suit yourself. Another short cut would be to find an old unit and rebuild it to your own desires. |
| which NAD older generation amps & integrated amps are bipolar or mosfet? | audionaut99 | Solid State | 3 | 21st May 2010 10:09 AM |
| For Sale: Tube Amps, Class-A Amps, BG Ribbons, Chassis and Other Goodies! | opc | Swap Meet | 23 | 2nd November 2009 05:04 PM |
| Big sale thread: PHL, Raven, Amps, In-wall/ceiling speakers, Amps, VideoRequest | mbcouple | Swap Meet | 2 | 27th October 2008 10:27 PM |
| Has anyone compared GC amps(LM3875/3886/4780) with other DIY SS amps(Leach,ESP) ? | percy | Chip Amps | 31 | 13th January 2006 01:33 AM |
| FS PA02 Power op-amps +/- 18v, 5 amps | modifry | Swap Meet | 0 | 11th August 2004 07:45 PM |
| Page generated in 0.08295 seconds (74.76% PHP - 25.24% MySQL) with 10 queries |
