diyAudio Sponsor
Old 23rd June 2010, 04:54 PM   #1
toufu is offline toufu  United States
Default Header bypass Cap?
I built the Aikido Phono Preamp and it work out well for awhile, but then I cleaned up the board, changed tubes and some resistors. Now my heater bypass cap keeps exploding, can anybody think of a reason? Is it a bad tube or is there something shorting? See the user guide below, it's on page 5.
Thanks!
http://www.tubecad.com/2008/07/13/PH...o%20preamp.pdf
Old 23rd June 2010, 04:56 PM   #2
kevinkr's Avatar
Thanks!
C16 capacitor voltage rating too low? Installed backwards or filament wiring polarity swapped?
www.kta-hifi.net
Old 23rd June 2010, 05:33 PM   #3
I installed a 35V cap and my heater is running at 12.6V and I checked the polarity as well. It was working fine until I changed the cathod resistors and the tubes.
Driver Bypass Cap - Value? batsong Tubes / Valves 2 28th April 2010 01:21 AM
Replace Bypass Cap? Monjul Tubes / Valves 42 9th April 2010 10:19 AM
Polar electro with bypass cap to replace nonpolar as coupling cap? at77 Parts 0 12th January 2010 02:05 AM
suitable bypass cap Stefanoo Solid State 0 26th May 2009 10:50 AM
orientation of bypass cap user_manutd Digital Source 3 30th March 2009 04:23 PM
Page generated in 0.06933 seconds (73.30% PHP - 26.70% MySQL) with 10 queries
