diyAudio Sponsor
Old 22nd June 2010, 09:26 PM   #1
Default ECC99/2A3 interstage finished, but have one query
I’ve just finished my second home-brew amplifier. It’s a simple two-stage circuit using an ECC99 to drive a 2A3 via a Lundahl interstage transformer. The two stages simply have a resistor and bypass capacitor from cathode to ground. The main purpose of this project was to build an amplifier similar to my first but use an IT to couple the two stages rather than a capacitor.
The only unusual thing I notice is a dip in frequency response of about 6dB at 30kHz. It dips fairly steeply from 20-30kHz and then gently rises back up between 30-50kHz after which it is flat to about 80kHz where it then gently rolls off. I have tried various loads on the secondary, both resistor and resistor/capacitor, but the response still follows the same pattern. Is there some inherent aspect of an IT that would cause this response? I cannot detect any audible effect, but I’m curious to know why.
Since I used many parts from the first amplifier to keep the cost down, it’s difficult to reliably compare the two, but I would say a small sacrifice in bass clarity has been compensated by the most lucid mid/top I can ever remember. The power supply is probably over-kill but it does mean absolutely no noise whatsoever, even at full volume position with 105dB speakers.
Anyway, I’d appreciate any feedback on the response anomaly, not with a view to change the circuit, but just to understand why.
Steve
Old 22nd June 2010, 09:35 PM   #2
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
that's probably because of inherent characteristics of Lundahl IT, combining with input capacitance ( Miller ) od 2A3 - in any case - nothing to write home about .
btw. visual design isn't my cup of tea , but execution is simply exemplary .....
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 22nd June 2010, 09:53 PM   #3
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
It is called ringing, frequency depends on transformers. Don't worry. Your design is exceptional, looks like a 21-st century cosmic ship. Very expensive look!
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 23rd June 2010, 10:40 AM   #4
Zen Mod, I know what you mean about the visuals, I wasn't too sure myself - it's just a bit in your face. I'm also limited by what I can lay my hands on at the time. For example, the mains transformer is potted into a stainless biscuit tin There are 6 large transformers/chokes inside the chassis and there wasn't enough room to get all the big poly caps in as well. If the caps had gone inside then all the trannies would have been a bit much on top. However, I do like working with stainless steel; nothing chips or flakes off, mistakes can easily be corrected, scratches are easily removed, and any level of polish can be put on the finish.
Old 23rd June 2010, 10:44 AM   #5
Zen Mod's Avatar
Old 23rd June 2010, 10:48 AM   #6
aptquark's Avatar
wow...
....wow.
Old 23rd June 2010, 11:00 AM   #7
Mighty splendid, just fab!
How many watts/kilo amplifier?
Old 23rd June 2010, 11:01 AM   #8
el156 is offline el156  Portugal
el156's Avatar
Beautifull looking ! Very nice!!!!!
Old 23rd June 2010, 11:16 AM   #9
SemperFi, if I was a salesman I'd turn that around. You get a whopping 15kg per watt.
The way litigation goes these days, I could probably get sued by a burglar who hurt his back trying to steal it.
Old 5th November 2011, 03:13 AM   #10
philo3 is offline philo3  United States
Meshplate, IMHO the visual design of your amp is awesome! I don't care what Zen Mod says.
ecc99 with which Interstage Transformer? AudioGeek Tubes / Valves 4 21st December 2010 10:22 AM
ECC99 line preamp kooltubes Tubes / Valves 39 18th February 2009 04:07 PM
ECC99 operating points? skyraider Tubes / Valves 6 22nd September 2005 08:13 AM
Just fired up my CCS'd ECC99 -> SE 2A3 Saurav Tubes / Valves 14 22nd September 2003 12:40 AM
JJ Tesla ECC99 as a driver for 300B-2A3 konstantin Tubes / Valves 6 1st July 2003 08:43 PM
Page generated in 0.10210 seconds (77.04% PHP - 22.96% MySQL) with 11 queries
