diyAudio Sponsor
Old 20th June 2010, 07:42 AM   #1
aldovan is offline aldovan  Brazil
Default 12B4 have a good sound ???
Friends
I need a small gain tube for replace a 6N6P in a pre-amplifier...
I think in use the cheap and robust 12B4 or 12B4A...
This tube have a fine sound ?
Anyone have experience with this tube ?
Thanks,
Aldovan
Old 20th June 2010, 11:08 AM   #2
el156 is offline el156  Portugal
el156's Avatar
Originally Posted by aldovan View Post
Friends
Thanks,
Aldovan
Hi !
I made some tests with 12B4A and was very positive! i like the sound very much. Go ahead with it ! And tell us the results.
Um abraco de Portugal
Silvino
Old 20th June 2010, 12:13 PM   #3
Tubie Noobie
There is a lot of fans of the 12b4 in here, myself included. Do a search in this forum and you will find many "operating" points for optimum sound.
Living Life Doing the Waltz in 4/4 meter.
Old 20th June 2010, 06:21 PM   #4
Default 12b4
Originally Posted by el156 View Post
Hi !
Silvino
Silvino
Thanks, I will make some tests with this tubes !!!
Gosto muito de Portugal !!! ( I like Portugal !!!)
Um abraço, ( a hug)
Aldovan
Old 20th June 2010, 06:22 PM   #5
Thanks for the opinion, I will build a stage with this tube.
Aldovan
Old 20th June 2010, 08:19 PM   #6
Tubie Noobie
the 12b4 or 12b4a is not without it issues either. It is a current hog, most people operate it around 17 - 25mA. If it is the input stage of the amp you will end up with a low impedance feedback loop if you use cathode feedback. Some of the tubes are microphonic, and all of mine tend to be more on the noisy side. I can hear a slight hiss, with 90dB speakers and 31dB gain on the amp.
I have not had stability issues but some claim that the tube is marginal with a CCS as the anode load. I presently use a resistive anode load and a bypassed CCS in the cahode circuit. I also run 21mA @ 150V. I do plan on experimenting with it next fall to find its true sweet spot.
The tube is imho worth the effort. I find it to be very neutral and also detailed. I dislike an overly warm sound that some tubes tend to give.
Old 20th June 2010, 08:30 PM   #7
And what brands have best sound ?
RCA is fine ?
I will use with 20 to 25mA x 90 V( plate).
Aldovan
Old 20th June 2010, 08:33 PM   #8
Tubie Noobie
RCA and GE JAN issued. Both sounded good.
Old 20th June 2010, 08:44 PM   #9
Fine.
I found some GE used that I removed of an old HP tester.
I will make some tests tomorrow and post the results here.
Thanks.
Aldovan
Old 21st June 2010, 05:04 AM   #10
FullRangeMan's Avatar
Alô Aldovan,
Você constroi valvulados?? Por acaso você já fez algum SET com a GM70??
Sempre é bom saber quem está construindo valvulados, pois gostaria de um SET GM70 no futuro.
Saudações, Gustavo
>Never go to a psychiatrist, adopt a cat or dog from the streets. On the streets pets live only two years average.
Yet another 12B4 line stage, or is the 12B4 better than the Grounded Grid..... Mark A. Gulbrandsen Tubes / Valves 789 8th March 2011 12:04 AM
Is 12B4/A good for differential pair? leadbelly Tubes / Valves 3 19th January 2006 08:09 PM
12B4 Battery Bias from (Preamp: Foreplay or 5687 or 12B4 ) DougL Tubes / Valves 3 2nd August 2004 06:06 PM
Page generated in 0.10522 seconds (83.12% PHP - 16.88% MySQL) with 10 queries
